It needs gas and battier to work
SOURCE: nail gun won't fire
Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
SOURCE: Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
SOURCE: Rebuilt nail gun and now it just blows air out the exhaust port
This probably is the problem,
The cylinder that the piston moves up and down inside is probably to low, and not making contact with the rubber piece in the head cap.
The cylinder has a spring that allows for movement up and down, take a pliers and gently pull up the cylinder if it does not move freely on its own. It will stop when it reaches the cylinder plate ( the part with 2 screw holes for easy removal). Be careful not to mar the cylinder though.
When reassembling the cylinder should make contact with the head cap. Hope that works!
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
SOURCE: Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Testimonial: "Thanks for that, i will look into it! Thanks for your time.... Cheers, Steven. ;-)"
