If this is being used in a commercial setting (I presume it is as it's a D300) the first things I would check is
1 outlet / breaker box /main electric panel
2 Cable from outlet to mixer if the outlet is hot
3 Timer Start Stop switch
4 Motor capacitor
5 Motor (this is ugly as it has a number of electric parts that could have gone bad)
That's the best I can do without further clarification. How did you find it was dead? Did it die while it was in use? Did it make any strange noises? Did it smoke? Do you get any response at all when you turn it on? My first reaction if the cord and outlet are good then I would be looking to the On/Off Timer control switch. It is the most logical if the mixer has not had any other instances of smoking lagging struggling with mixes or advance warning of a problem. It is the most likely answer that a contact is not working. Press all switches and buttons to see if any feel stuck in place. It may be that you only need to open the switch panel and clean out the flour and other gunk. I hope this helps, if so let us know we love hearing from you about a good solution.
