I cannot get my computer to accept my older printer. I do not know where the original software disk is.
The "connection" is a cable, (or wireless when available,) and NOT software.
That said, a PC needs 'drivers' to run hardware devices. You would find these drivers on the manufacturers website. Yours is HERE.
You will need to choose the correct Operating System for your Laptop.
Tallon41
SOURCE: Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
SOURCE: hp officejet 4315 all-in-one
Hi
Please click on the web link given below and perform the steps as provided in the web page to download and install the printer software on your Laptop.
Please connect the USB cable to the Laptop before installing the printer software on your Laptop.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1138342&cc=us&lc=en&dlc=en&product=1138342
Please select the Operating system you have installed on your Laptop.
This should fix the issue.
Have a great day!
SOURCE: Hp 6122 Printer Printer driver removal
I believe if you go to HP.com and do their auto-select printer routine it should delete the old driver for you.
SOURCE: priner disk lost fir my hp 1350 allin one printer
I lost the printer disk for my hp1350 printer and i need to hook it back up to my computer.
