It could be you opened the door before it had fully completed a program, and then turned it off. My Hotpoint machine has to be reset in these circumstances otherwise the next time it is turned on, it appears to let you select a different program but when you close the door resumes the program it was running when it was interrupted.
You don't say which model you have, so I cant give you a definitive answer, but you could try the following sequence which works on my Hotpoint:
1. Open door and switch machine on.2. Press and hold down the P button for several seconds until it gives a series of beeps (mine = 3 beeps).3. Release P button.4. Select the program you want in the usual way using the P button.5. Close door, and the machine should then run the selected program.
Hope this helps.
SOURCE: My kenmore elite ultrawash dishwasher,
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
SOURCE: Used some washing up liquid instead of dishwasher
dear sir vif you have used liquid soap in your dishwasher it will make mountains of bubles to kill all bubles outin a hurry take a sos pad put it in your machine and run the dishwaser this will remove all of the soao instantly try it it really works i am in the dishwasher bussiness and it does work thanks from gilles
SOURCE: neff dishwasher s5433xogb/29 pump keeps running
Our Neff Dishwasher S5456X0 the pump was running all the time and the solution 1 worked. We removed the front panel under the door and the the flood camber was full of water. Drained it out with a sponge and the dishwasher is fine. Thanks
SOURCE: dishwasher going straight to end when starting
Removed tall wine glasses from under the water jet.(must have been too close) and all OK!!!
SOURCE: When dishwasher is turned on (regular wash
Do you have any of the lights flashing?
There are two possibilities -
1. the door switch is not sensing close correctly. This will prevent dishwasher from starting.
see this diagram for location etc. It is item 3.
or
2. you have Aquastop device installed in the inlet water connection which has been triggered due to a leakage. This can prevent water from coming in.
Please post your comment to confirm what you find.
Hello &
Welcome to FixYa
To unlock the
controls press and hold the HEATED DRY button for 20seconds. If the problme
returns then only option is touch pad replacement. Please get back to me if you
have any other questions.
Kevin
