Question about Janome Harmony 1017 Sewing Machine
Where can i get a presser foot for a Janome 1017
Posted by Dorothy Windham on
  • Dorothy Windham Sep 21, 2012
    I put the wrong thing on my post. I am sorry. I need to know where to get a power cord for a Janome 1017.
  • I suggest you go to these sites & email them or call them,, sewvacdoctor.com & a1sewingmachines.com
Debbi's Sewing Machine Repair
  • Janome Master
  • 7,365 Answers
Posted on Sep 19, 2012
Testimonial: "Thank you, Debbi. I appreciate all the links you provided! "
5 Related Answers
Robbie Brewington
  • 255 Answers
SOURCE: The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Posted on Jan 27, 2010
SOURCE: how to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Posted on Feb 23, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: I need to replace the metal bar that snaps onto the presser foot.
If you go to the Janome website of your home country they will have a dealer locator page where you can find your nearest dealer.
Explain the problem and they will be able to order the replacement part for you.
You may find that parts availability at this time of year will be restricted as many businesses and suppliers close for several weeks.
Posted on Dec 28, 2008
Anonymous
SOURCE: I have a Janome 11000-it won't embroidery
You have to be sure you have the correct foot on the machine and that it is put on correctly. You can't use a regular foot - you need to use the embroidery foot P, which require you to remove the foot holder altogether, and put on the P.
Posted on Jan 03, 2009
SewTechWayne
SewTechWayne
  • 186 Answers
SOURCE: MC 11000 janome stops reading presser foot "p"
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
Posted on Feb 08, 2009
I have installed a Janome Walking foot on my Janome Skyline S5 and have the feed dogs up, but the foot does not touch the quilt sandwich or pull the sandwich through. What do I do?
You have the presser foot lowered? All I can think is you may have the wrong walking foot. It should be the same height as your regular presser feet.
Jan 31, 2018 | Janome Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
How do I adjust the presser foot pressure on my Janome 7100QDC
your model doesn't have this feature Janome 7100QDC Computerized Sewing Machine , it it did, there would be a knob on the top left of the machine above the presser foot which you could screw up or down to increase or decrease the pressure. Its not a feature on many machines, the presser foot bar has a big spring internally which applies the pressure and this will just adjust to suit the fabric under the foot.
Mar 01, 2015 | Janome Sewing Machines
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
Raising presser foot on Janime 2212
http://content.janome.com/userfiles/file/Inst%20book_%202212%28En_Sp_Fr%29.pdf
See p. 10 of the manual.
The presser foot lifter is on the right side of the leftmost part of the machine, towards the back of the machine. Press up to raise it.
Feb 16, 2014 | Janome Sewing Machines
Button holes foot
http://content.janome.com/userfiles/file/Inst%20Book%207318%20%28English%29.pdf See p. 22 You snap off whatever foot is currently on, and snap on the buttonhole foot, #J.
Jan 12, 2014 | Janome 1017 Mechanical Sewing Machine
The presser foot on my Janome MC9000 will not go up or down
yeah the cam lever is probably broken. Time for a new machine???
Oct 24, 2012 | Sewing Machines
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
Hello, just a few quick questions. I have a Janome Harmony 1017 machine and I want to know if it is an oscillating hook or a rotary hook machine. Also, I was given a rolled hem foot and a zipper foot but...
The easiest way to know is to look at the bobbin case and if it has a finger sticking up then it is oscillating, plate If you have snap on feet to take the foot off just push the front of the foot up, to put the foot on, rest the foot on the needle plate then lower the presser bar down on top of it to snap on
Aug 09, 2011 | Janome 1017 Mechanical Sewing Machine
Janome Harmony 1017 Sewing Machine Logo
612 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
