How do I reset camera to factory settings
SOURCE: canon power shot s5is
to the right of the mode selector dial and in front of the off button is a small button with a square with 2 little "L" shapes wrapped around its corner a "/" and a circle with a spot at the top and a line pointing to the 11oclock position. Press this button and use the left and right (just below the "+/-" button and just above the "set" button to scroll through the options on the screen.
this should give you the options of single shot, 2 second and 10 second self timer and the change delay option
see page 18 of the manual available from here wss.com/gds/0900009897/PowerShotS5IS_CUGba_EN.pdf">http://gdlp01.c-wss.com/gds/0900009897/PowerShotS5IS_CUGba_EN.pdf
once finished with the timer you press the timer button again..
best of luck
SOURCE: How to set self timer and take picture
Press the self-timer button and use arrow buttons to select the delay time, press MENU to confirm. More detail please read the user’s manual on page 68.
Here is the link of the manual http://gdlp01.c-wss.com/gds/0300001224/PSSX110IS_CUG_EN.pdf
SOURCE: When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
SOURCE: question, I have a canon power shot S3 I reset my
Buy a recover software or send your card to some shop. Cost about £25.
1. Make sure camera is off, and then remove the batteries and memory card.
2. Close the battery door.
3. Press and hold down the on/off button for 1 minute.
4. Release the on/off button, and reinsert the batteries and memory card.
5. Power the camera on.
Settings Reset
Next reset the settings of the camera to the factory default.
1. While the camera is on, press and hold the menu button for approximately 10 seconds.
2. The screen should then display the message "Reset settings to default".
3. "Cancel" will be highlighted so move to the right and highlight "OK".
4. Press the SET button once "OK" has been highlighted.
5. The screen will say "busy" while the settings are returned to the default
Hi Nick,
The DSCW210 Camera is compatible with the Memory Stick ProDuo up to 32GB. The Camera will not recognize the Memory Stick if it is formatted in the Computer. Try removing and reinserting the MS and check if it helps. Try using different MS to check if the issue is with the MS or with the Camera. Try resetting the Camera and check if it helps.
Performing a manual power reset may help:
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks.
KenSolutions
FixYa
