Cell Phones Logo
Question about Cell Phones
My SGH-A411 Sumsung phone is saying phone freeze contact provider. How do I solve this problem?
IMEI: 357027/480454/8
Posted by Kenny Bisha Goma on
Anonymous
    New Friend:
  • 14 Answers
You need to Unfreeze it..You can get the Unfreeze code for SAMSUNG SGH A411 (A411) phone from the site
Classicunlocking.com and unfreeze it..check whether Unfreeze service is available for your mobile's locked network and country.If it's available get unfreeze code and unfreeze it.
Posted on Oct 08, 2012
5 Related Answers
Anonymous
  • 7752 Answers
SOURCE: phone freeze unlock code
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
Posted on Jan 13, 2008
Anonymous
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000# If your phone says wrong password, turn your phone off and put in an unaccepted Sim Card into the phone (A sim card from another Service Provider) and then start the process over again. If it says wrong password even with the wrong Sim card, then you have reached your second attempt, Do NOT try it again. Instead, go to Ebay and purchase an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now that you know your phone's unlock code, (00000000) you can use the following codes to unlock individual locks on your phone (Where you see the word Code you will put in your new unlock code, which is now 00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
Posted on Mar 02, 2008
Anonymous
  • 271 Answers
Hi ,
you can download unlock client from below site
http://www.mobile2mobile.net/unlock/Remo... http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm?gclid=CLzQwIOBqYsCFQ-Wbgod2n3IjQ
PLEASE RATE ME...........................................
Posted on May 22, 2008
Service Dude
Jonathan Van Rensburg
  • 201 Answers
SOURCE: unlock code for samsung sgh-a411 please
Fully charge your phone the with no sim try *2767*3855#
Posted on Apr 24, 2009
Anonymous
SOURCE: samsung z400 phone freeze
hi i have a z400 how ever when i search for devices via bluethooth or people search for me im unable to send or recieve files
Posted on Jul 24, 2009
I want to sumsung sgh t-459 unlock code.Imei is 35306103834021703
To unlock Your samsung Phone get the unlock code from the site Simpleunlocking.com and get Free Unlocking instructions from the site Mobileunlockguide.com/samsung-sgh-t459-gravity and unlock it easily...
What is the procedure to unlock a Samsung SGH-A411 mobile phone?
you can unlock your phone here http://www.superunlockcodes.com/samsung-a411/rs12wp9/
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
Jan 07, 2011 • Cell Phones
I have a sgh a411 old phone that gives the message phone freeze sim unavailable.....I have the unlock network code but it seems I've already stuffed things up because it is frozen. The phone is not frozen...
It may be due to network lock,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.prounlocking.com/samsung-sgh-a707-sync/rs8wp9/
5helpful
4answers
Samsung SGH-A411 Network Unlock Codes
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
1helpful
SGH-A411 problem
No basic ally it means ''contact service provider'' Be warned Some Networks charge for this information.
your network will give you a pin to unlock your phone, Basically putting in some random code from the internet has BRICKED your phone its worth less unless you get this unlock code.
2helpful
Samsung u700
Unfortunately, a Samsung in Phone Freeze needs to be reflashed with new firmware.
This happens when a security code is entered incorrectly too many times, permanently locking the phone.
You can either send it back to Samsung, or look for a service center in your local area that can provide software support for you Gleam.
Sorry for the bad news.
Please rate at least as helpful as there is no fixya solution anyone on here can provide for Phone Freeze.
Sgh-a411 phone freeze
Hi, This message comes up when i insert my own sim.
Phone Freeze SIM Unavailable Please Contact Service provider.
What to do?
44helpful
6answers
Phone lock SGH - A411
take the sim out of the phone, turn it on and type *2767*3855#. this will reset the phone and take off any codes.
Feb 18, 2008 • Nokia 7610
108helpful
24answers
Phone freeze unlock code
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
