Samsung SGH-R225m Phone Logo
Question about Samsung SGH-R225m Phone
Unlocking sumsung sgh-a411 which is saying phone freeze contact service provider
Posted by Kenny Bisha Goma on
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: SGH-A411 problem
No basic ally it means ''contact service provider'' Be warned Some Networks charge for this information.
your network will give you a pin to unlock your phone, Basically putting in some random code from the internet has BRICKED your phone its worth less unless you get this unlock code.
Posted on Nov 15, 2008
Anonymous
  • 17 Answers
SOURCE: hi i need a un freeze code for a samsung gt s5260
I will help You,it's says Sim Freeze means it locked to Network,you have to Unfreeze it.for that You need to use the Unfreeze code,you can get the Unfreeze Code from here Simpleunlocking.com and unfreeze it,then you can use any GSM Network Sim card in the Phone...
Samsung S5260 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung S5260 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung S5260 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung S5260 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung S5260 is locked to.
CODE: Its the unique Unlock Code for your Samsung S5260.
Posted on Aug 11, 2011
Anonymous
  • 20 Answers
SOURCE: phone freeze unlock code
You have to send the phone away for repair.
Posted on Jan 01, 2008
Anonymous
  • 7752 Answers
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
Posted on Jan 13, 2008
Anonymous
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000# If your phone says wrong password, turn your phone off and put in an unaccepted Sim Card into the phone (A sim card from another Service Provider) and then start the process over again. If it says wrong password even with the wrong Sim card, then you have reached your second attempt, Do NOT try it again. Instead, go to Ebay and purchase an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now that you know your phone's unlock code, (00000000) you can use the following codes to unlock individual locks on your phone (Where you see the word Code you will put in your new unlock code, which is now 00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
Posted on Mar 02, 2008
My SGH-A411 Sumsung phone is saying phone freeze contact provider. How do I solve this problem?
You need to Unfreeze it..You can get the Unfreeze code for SAMSUNG SGH A411 (A411) phone from the site
Classicunlocking.com and unfreeze it..check whether Unfreeze service is available for your mobile's locked network and country.If it's available get unfreeze code and unfreeze it.
Sep 18, 2012 • Cell Phones
2answers
NEED UNLOCK CODE FOR att sUMSUNG sgh a867
You can unlock your Samsung SGH-A867 using codes!! Unlocking using codes is easy and also safe!! You can get the codes from your service provider or from any reliable online sites like classicunlocking.com and for unlocking instructions you can visit mobileunlockguide.com , here you can get simple and step by step instructions to unlock your phone!!!
What is the procedure to unlock a Samsung SGH-A411 mobile phone?
you can unlock your phone here http://www.superunlockcodes.com/samsung-a411/rs12wp9/
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
Jan 07, 2011 • Cell Phones
I have a sgh a411 old phone that gives the message phone freeze sim unavailable.....I have the unlock network code but it seems I've already stuffed things up because it is frozen. The phone is not frozen...
It may be due to network lock,
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
http://www.prounlocking.com/samsung-sgh-a707-sync/rs8wp9/
Phone freeze unlock code
You don't have to do anything just type this code on your dial screen : #7465625*2877#
Don't use your own code.
5helpful
4answers
Samsung SGH-A411 Network Unlock Codes
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
1helpful
SGH-A411 problem
Sgh-a411 phone freeze
Hi, This message comes up when i insert my own sim.
Phone Freeze SIM Unavailable Please Contact Service provider.
What to do?
Top Samsung Lands Phones Experts
Marvin
Marvin
Lawrence Oravetz
Ngoro
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
