Question about LG 5.1ch 1100w bluray hts 5 speakrperp ipod dock dolby truhd dts ne l
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
I cannot hear sound from the rear speakers or the Centre speaker. I am playing an IPOD on the inbuilt dock. I think that I need to change from Stereo to Surround sound, but I am not sure how to do this
Posted by k webb on
Jarad Thomas
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Posted on Feb 08, 2013
3 Related Answers
Anonymous
SOURCE: Surround speakers don't work
Check which Channel you are using on the Remote. i.e. 2.1 Multichannel or Auto the Centre Speaker and the 2 rear speakers don't work if its 2.1 channel setting
Posted on Mar 18, 2008
Anonymous
SOURCE: no surround on LG HT904 when using iPod
TRY TO CHOOSE THE SOUND TYPE TO BE MATRIX
Posted on Feb 03, 2010
Azrael SRL
  • 11800 Answers
SOURCE: LG HT752TH Surround sound system rear x2 and
They will work only if the source signal is itself 5.1. If it's stereo then you must convert it to 5.1 using the Virtual sound setting (press VSM to access it and select 5.1).
Posted on Sep 02, 2010
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
Hi. I just bought a new JBL On stage micro III. The problem is that when I put my Ipod on the dock the sound only comes from the iPod and the speaker doesn't produce any sound at all but when I push...
Have you made sure the dock is compatible with the iPod version you have? If you are having to move the iPod around, this may be because the dock isn't built for the iPod you own.
It could also be a technical fault that the dock is loose. Take it/send it back to the shop and explain your problem.
May 06, 2011 | JBL 6-1/2\ Round Coaxial Speaker By...
My sony dav dz270 home theatre has no sound through centre and rear speaker
You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
Mar 14, 2011 | Sony DAV-DZ720 Theater System
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
LG HT752TH Surround sound system rear x2 and centre speakers do not work even tho connected and tested correct.
Sep 02, 2010 | LG LH-T754 Theater System
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
No sound from my Pure-Fi Express plus into my 4th gen Nan Ipod
Hi, while your pure express plus you just purchased is not playing out any sound is because, the speaker that enable you to play the sound when you play music through the ipod is faulty and it needs to be replaced with another one for it to function properly again.
After changing the speaker that is faulty with a new speaker, you can now start enjoying the music again through the internal speaker.
Take care.
Apr 14, 2010 | Apple iPod nano
LG 5.1ch 1100w bluray hts 5 speakrperp ipod dock dolby truhd dts ne l Logo
177 people viewed this question
Top LG Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
