Question about Badgley Mischka Crystal Design Bracelet Watch Gold One Size
How to remove pin from band - Badgley Mischka Crystal Design Bracelet Watch Gold One Size
Posted by imdabomb1976 on
  • Badgley Mischka Master
  • 18,429 Answers
I have a Casio (593 F91W) and cannot get the pins out to change band. Jeweler cannot get the pins out. What is the secret?
It's likely that your band pins are thin and do not have collars that can easily be grabbed by most band removal/installation tools. If you are already changing the band, the best thing to do would be to cut off the band so that the pins are clearly visible, then use a set of nipping pliers to cut the band pins in the middle. At best, you'll cut them in half; at worst, you'll bend the pins into a "V" that will pull at least one end out of their holes. Obviously, you'll need fresh pins with your new watch band.
Efforts to dig the pins out of their holes can easily damage the holes themselves, making the watch useless.
Apr 26, 2011 | Casio Classic Black Digital #F91W1 Watch...
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
    mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
    Jul 21, 2010 | Seiko SGF204 Wrist Watch
    Replacing watch band on pathfinder pas410. can't get pins out to replace band.
    Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
    Rate me, plz.
    Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
    How to remove links?
    Assuming this is NOT an expansion band, there are generally two different types of links: one is a straight pin or cotter pin, the other is an "L" shaped pin. Look at the side of the band. If there is a small round hole it's either a pin or cotter pin. On the inside of the band, there is quite often an arrow that indicates the direction you need to pump the pin to remove it. I have several different tools for removing pins, but you don't need to use a special tool if you're patient and careful. You can use a stiff wire and gently hammer on the end of the pin to push it out. You will need an open area above the head of the pin so it has someplace to go when it clears the band. With the head of the pin sticking out, grip with a pair of pliers and pull. Same process with a cotter pin. Installation is the reverse of removal only you are travelling against the arrow. Once you have the pin almost all of the way in, I pick up the watch and press the head of the pin against the corner of my workbench to push it in the rest of the way. For the "L" shaped pins, they are trickier. I made a special tool for that, but you aren't going to want to do that. If you have an awl, you can brace the edge of the band against a soft metal such as aluminum so it won't scratch. On the inside of the band, you will find the arrows showing the direction you need to go to remove the pin. Youwill also see a small hole along the outer edge of the band. Put the tip of the awl at a low angle against a protrusion that you can see in the hole. Gently tap the awl in the direction of the arrow. When youcan see enough of the pin sticking out the side of the band, you can grip it with a pair of pliers and pull it out the rest of the way. Installation is the reverse of removal. Again, use something to push the head of the pin against.
    Jun 14, 2009 | Casio G-Shock MTG930DA-8V Wrist Watch
    Want to fit a watch band. take links out.
    You need a link tool. You can purchase this item on Ebay or watch parts sites. Some have a little track that you put the band on and screw a pin into the pin on the band and it pushes the split pin out and you remove the link. Pay attention to the pins on the band. You need to push out the side with the split pin that looks like a flathead screw. It sometimes is. In most cases it is a pin. When the link is removed you have to connect to the next link and push the pin into the hole again and it shoul go in the direction of the other pins. The pin should go in on the side with the split looking pins. You will need special tools: pin pusher device, a pin block and hammer with pins to hammer out the pins on the band usually. Some or most folks take classes to learn this but you may be handy and figure it out.
    Dec 03, 2008 | Invicta Watches
    Watch band
    I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
    Tools:
    1 push pin like you use on bulletin boards with a plastic head
    1 small hammer like a tack hammer
    1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
    1 small block of wood
    Try to pick a well lit table in a room where you will not be interrupted.
    Procedure:
    1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
    2. Carefully line up the push pin point with the top of the pin.
    3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
    4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
    5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
    6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
    Dec 25, 2007 | Fossil AM 3688 Wrist Watch
    Badgley Mischka Crystal Design Bracelet Watch Gold One Size Logo
    106 people viewed this question
    Top Badgley Mischka Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Badgley Mischka Watch Expert? Answer questions, earn points and help others
