Question about La Crosse Measuring Tools & Sensors
Need a manual for the lacrosse 7159 weather station
I can't remember how to set the weather station
1 Related Answer
Okeoma Emmanuel
  • 1156 Answers
SOURCE: My weather station by Lacross will not display the
http://www.lacrossetechnology.com/9611/manual.pdf
If that's not the right manual,you can use the link below, and select the model..If the model is not there, that means the manual is not available...
http://www.lacrossetechnology.com/support/manuals.php
Take care
Posted on Jun 15, 2011
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
What's your problem?dr. Tech WH-1170T User Manual
how do I change the time to regular settings from 24 hour.
Aug 18, 2012 | dr. Tech WH-1170T Wireless Advanced...
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
Software for Weather Station EC-WS115
reguire driver/software for ec-ws115 wireless weather
Apr 01, 2012 | Measuring Tools & Sensors
How can I get intructions to adjust the data on my RCA WERE 1001 Made in China Black oval approx 5 1/2 " high weather station?
You should be able to press and hold the 'set' button on the back of the unit, then press the + or - button, also on the back, at the same time as pressing the 'set' button. Hold for about 2 seconds and it should beep. then it is just a matter of going through each item on the station and adjusting the time, etc., with the + or - buttons.
Jun 09, 2011 | RCA WERE1000 Weather Station
Measuring Tools & Sensors Logo
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
