Probably you did not need to replace those, are both cylinders running? was the motorcycle sitting for any length of time? make sure the carb low speed jets are clear use carb cleaner the can with the with the tube and make sure the low speed jet will flow the fuid through it. if its clogged take a strand of copper wire and clear them.
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Only place to get that is from the dealer or go on line to alldatadiy.com and buy a one year subscription for your car and it will have the locations on everything on the car, you might get the dealer to give you a printout for it as well, they may or may not charge you for the service.
