More then likely a blowen seal on head. Take to dealer and have it checked if you catch it befor it go's completely out it shoulden cost as much to fix. But it is going to cost . good luck
P0444, Evaporative Emission System Purge Control Valve Circuit Open". I believe this (small) valve is located underneath the intake manifold behind the oil filter housing. Since there are other codes that indicate leaks in the evap system, you might have to replace the PCV, P0604 could be the coolant level, or a stuck thermostat, top up the coolant, or replace thermostat would be advisable.
hope tis helps
its no code to reset engine light you need to scann the ecu wjit a scanner and see .. if the light is no its because the ecu see a problem end need to fix the problem to rest the light
code po444 is referencing a purge control problem. this could be a bad connection or a problem with the purge solenoid for the evaporative system(EVAP). this is controlled by the PCM to allow fuel vapours to be drawn into the engine and burnt from the gas tank under certain conditions. the p0174 is a lean running condition on bank 2 and p0171 is a lean running condition on bank 1. the lean running conditions could be O2 sensors, lean condition caused by bad fuel pressure, dirty injectors, bad MAF sensor, vacuum leak.
Possible causes- Evaporative Emission (EVAP) Purge Solenoid Control harness is open or shorted - Evaporative Emission (EVAP) Purge Solenoid Control circuit poor electrical connection - Faulty Evaporative Emission (EVAP) Purge Solenoid Control
CODE PO562 SYSTEM VOLTAGE LOW.THIS COULD BE THE PROBLEM.YOUR ALTERNATOR NOT CHARGING.NOT ENOUGH POWER TO RUN THE PCM.HAVE YOUR CAR CHARGING SYSTEM CHECKED.
the purge valve i believe is located near your gas tank unless theyve moved it i should look like a little canister cyclinder shaped. both codes could be set off by the same problem. try replacing the valve.
