My laptop was going slow and it took way too long to open any program. I tried to do a complete factory restore with acer erecovery management. However, for the first few minutes, the restore was going ok, but at 92 percent it got stuck and I got an error that said the restore failed. It was error 0x45d. Please help!
SOURCE: Acer eRecovery Wont Work
ok u can restore ur notebook to factory defaults without disk like this
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
pls rate me FIXYA !! or ask for more help
SOURCE: restore acer aspire to factory setting
For all Acer Netbooks try to initiate the recovery using Altgr key (righthand side of the space bar) and F10, ie Altgr+F10 as soon as the computer restarts. If the recovery partion is corrupted or do not have the CD. Try the below steps:
No Restore CD / eRecovery / password / ALT + F10 or F10
1 - Recovery of data on the hidden partition PQSERVICE for password
A - Installing the software R-Drive Image to create an image of this partition (this file has the extension. ARC)
B - Always with this software, create a virtual disk logic to see the files
C - From the desktop, go to the newly created virtual disk and find the file aimdrs.dat. The open with the notepad and get the password.
2 - Reactivating the ALT + F10
A - Always on the virtual disk created, find 2 files: mbrwrwin.exe and rtmbr.bin.
B - Copy these 2 files on drive C: \
C - Since the MS-DOS (Pocket PC) to C: \, type the following command: mbrwrwin install rtmbr.bin
D - The function has been reactivated.
3 - Start of Restoration
A - At the start of the PC, go to the set-up to check if the function is well on D2D enabled (normally it is a default setting ... but hey you never know.)
B - Once the audit and that the PC has restarted once the ACER logo appears, simultaneously press ALT + F10 to start the restore utility.
C - When it asks for the password, you need to type one found in the file aimdrs.dat. CAUTION: The keyboard is QWERTY mode so we thought enter his password, but as some letters are reversed, it does not work.
4 - Normally at this stage there ... everything works and restoration is smooth.
Note: If the operating system does not work, it is possible to do this from another PC by connecting the hard drive or USB slave
SOURCE: Acer laptop restarts repeatedly to acer erecovery management environment
did you reformat the hard drive first?if not then you needed to ensure that you selected 'repair' first.
SOURCE: erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
SOURCE: forgotten password on my Acer eRecovery Management
If you fully formatted the hard drive then most probably you have cleaned the PQservice division which might had recovery data; you can check this with the help of Computer Management console in Windows. It is in Windowssystem32compmgmt.msc. Also check the Disk Management
and see what partitions you still have. Acer eRecovery Management won’t
work if there is no default partition i.e. There should be E or D
partition in order to run it.
Try www.download.com Here you might find your required software or else you have to ask the supplier to fix this problem for you. Hope this helps!
Click "Start" menu.
Click "Programs."
