SOURCE: i bought a 2gb micro sd card ,i can"t put any files
SD cards and microSD adaptors have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: Micro SD 2GB
thats the same problem im having!! its getting annoying. if you find the solution could you plz email me it... [email protected] names allison thank you
SOURCE: 8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
SOURCE: PNY 2GB MICRO SD MEMORY CARD NOT READING!!
In this case, it sounds like the card is bad. All you can do is try to clean the gold fingers with a soft cloth and alcohol, and hope that works. It may have corrupted data on it, and be unusable. The best way to know is to buy another one ($9 at Walmart), and then you will at least verify that your phone and computer are good, and the old card bad. Hope it's just dirty fingers, good luck.
