SOURCE: DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
SOURCE: Panasonic DMR-E80H Change Disc Error
If you haven't done so, try downloading the firmware update from their support site. Burn the update file to a cd-rom.
I have had numerous times where my unit recovered and I had to format the hard drive(losing all of my shows), but since I did the update this has not happened to me again.
SOURCE: recording from hard disk to dvd
Must be a trick question... it has a recordable drive.
No to DVDs, Yes to DVD-R, DVD RAM, DVDDL
SOURCE: my dvd recorder dmr e85 h panasonic dont rec dont
A DVD Recorder needs to play before it can record. Not accessing the hard drive as well indicates a problem with the power supply inside, more than likely. Time for a reputable repair shop.
SOURCE: my Panasonic DMR-E85H DVD Recorder's hard drive
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
Testimonial: "Thank you."
