1994 Buick LeSabre Logo
Anonymous Posted on Dec 26, 2008
94 buick lesabre security light flashing
Im not getting any power from my ignition to start my car,but lights radio etc.. is all working I need Major HELP.
  • Anonymous Dec 27, 2008
    yes security light is flashing,but i have done no repairs except got new battery and a spare key made because a guy put his diagnostic tool on it and it said, pass key error or data key error something like that,but it still does the same thing
  • Anonymous May 11, 2010
    Hi...
    Ok.. The security light is flashing?. You did any repair on in the steering column or ign. cylinder.?.
    Letme know.
Anonymous
Level 3:
  • Master 373 Answers
  • Posted on Dec 27, 2008
Anonymous
Master
Level 3:
Answers
373
Questions
Helped
324492
Points
1445
Ok..
Your vehicle is equipaded with Factory Anti Theft System.
Called Pass key II . If the mechanic found the Code
Pass key error....
Is there a few test to Do. to know exactly the problem.
1--- check if the Old and New key Are equipaded with a Little thing (Chip or Ressistence) in the center of the key.
If not you need a key with the chip. and the correct Ohms.
2. If you just replace the battery,
Full charge the battery Attemp to start the vehicle and leave the key in run position for exactly 11 Minutes, Them turn the key to off position for 30 seconds and try to start, if the vehicle start . you did the prosses to program the key.
If the vehicle not start.
Some times this procedure will require Up to 3 times to setup.
Or more with intervals of 30 minutes,, But if not start.
Remove the lower cover of the steering column. and the the Connector orange with 2 white wires shielded with a orange cover.
NOTE.. Be sure to not Confuse with the Yellow wires and connector, They are for the AIR BAG. Dont use a Convencinal Test light on any of the Mentionated wires....
After you find the wire and saw everything ok.
3-- You will need to remove the Ignition Lock cylinder.
The ignition lock cylinder is use 2 white wires shielded with orange cover, On 90% of the cases one of the wires come broken. and the ECM loss the comunication with the Chip incrusted in the key..
2answers
Car will do nothing. as if the battery wasnt hooked up. has new battery. no lights. NOTHING
2001 Buick Lesabre: Car Will Not Start Does Nothing Took ...
www.2carpros.com/questions/buick-lesabre-2001-buick-lesabre
Apr 22, 2007 - Car will not start does nothing took battery out to get tested because it would not jump start battery found to be good put battery back in ...
how to fix a buick century that wont crank - YouTube
? 2:44
https://www.youtube.com/watch?v=UWfvEouMMtc
Dec 18, 2009 - Uploaded by jay eltatertoto
how to fix a buick century that wont crank. jay eltatertoto ... How to easily fix a Buick that will not crank and security light flashing - Duration: 6:06. ... My Car Wont Turn Over - How To Test The Starter / NSS / Ignition Switch - Duration: 5:21. ... 2001 BuickCentury Custom - Duration: 19:44. uxwbill 19,621 views.
Car Won't Start Because of Anti-Theft System That Uses ...
repairpal.com > Problems > Buick > LeSabre
I have no power anywhere. i can jump solenoid and engine turns over but no fire. i suspect ignition switch but would that cause no power through out the car?
The fact that you can turn the engine but not get it to fire would suggest the battery is ok. The fact that you have no headlights, dash lights etc. would point to blown fuse/fuses. Even if the ignition switch was faulty you should still be able to switch the headlights on. I would check the fuses and the ignition switch wiring.
3helpful
My 2000 lesabre will start sometimes and wont sometimes. for the last wk it wont start. it has power lights work everything just wont crank whats wrong with it. jf1
Hello: Make sure the battery cables are clean No corrosion, and tight. If the security light is not flashing when you try to start it, the have a helper hold the ignition switch in the start position and you go under the car and hit the starter (not to hard) near the end that goes into the engine, If it starts then you need a starter. If the security light flashes while trying to start you have a pass key problem
5helpful
2answers
94 BUICK LESABRE RADIO WIRING
1994 Buick Lesabre Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Stereo Radio Illumination Wire: Gray
Stereo Radio Dimmer Wire: Brown
Stereo Radio Antenna Trigger Wire: N/A
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
5helpful
2answers
1993 buick lesabre won't start. security light is
The coded key probably needs to relearn. Turn ignition to crank and release. Let sit in on position (engine off of coarse) for a full 10 min. turn off for 30 sec. and repeat 3 times engine should start. This procedure should take 30 min. so a booster is needed to maintain a full 12 volts. Do not attempt w/out a charger connected;
99 buick lesabre, battery ok, turn key to start, nothing
The security system (VATS/PassKey) is faulty. You can find a great write-up here: http://newrockies.ca , it was the only thing that saved my Park Avenue.
1helpful
2answers
Won't turn over , security light comes on when trying to start,
try puting te ignition key in the drivers door lock an unloack it 3 or 4 times then try agin if it dosnt work, key needs reprormming
1helpful
99' buick lesabre
the security light flashes on mine also. i think its just normal. don't worry about it.
2helpful
2answers
Replaced ignition and steering wheel now car wont start -security light on
first of all was the ignition dealer a lot of cars have a start chip built into the key if you did after market it may not be compatible with out bypassing key security chip with out the right key setup the car stays diabled
9helpful
6answers
1992 buick lesabre ignition problems
do you get a "security" light in the dash?
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
