Question about LG 50PX5D 50 in. Plasma HDTV
LG plasma TV Model PDP50X30010 went pop pop pop....no more picture
Went pop pop pop....no more picture
Posted by sglusman424 on
frederick daniels
    New Friend:
  • 3 Answers
Buy a new one sounds like its gone forever ?
Posted on Sep 16, 2012
5 Related Answers
wfdiver
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
Anonymous
SOURCE: LG 50PX4DR plasma tv
I had the same exact problem as posted above. My 50" LG plasma was out of warranty for 1 year! I called the LG executive call center, and they were very helpful. They offered to pay for the parts and labor. They recommended a few local repair shops, and they set everything up for me. The tech came out within 4 days with one part. The tech had to come out one more time the following week, since more parts were needed for the repair. The Y sustain board, along with 2 adjacent parts that are required to be replaced as a set, and the power supply had to be replaced (parts alone cost just over $900). TV is like new again; I'm very happy with how LG handled it, and made what could have been a bad experience a good one.
Posted on Apr 30, 2009
Anonymous
  • 3 Answers
SOURCE: LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Posted on Apr 23, 2009
David Low
  • 458 Answers
SOURCE: where are the video driver boards located when the back cover is?
When you remove the rear cover the video driver board is the centre board, this contains the ICs that process the audio/video signals that are inputed by either antenna/scart/hdmi sources. This is where the Cortez & Hurricane ICs are located. You can easily identify it as it is the board that has your input sockets attached to it.
Posted on Jul 01, 2009
Anonymous
  • 541 Answers
SOURCE: i have a lg 42pc3dv plasma tv. it made a loud pop
Looking at it from the back, the board on the left is the ysus. You should see a big red cable coming from the power supply board in the middle of the set going to the ysus. Near the red cable plug on the ysus should be a fuse. Most likely the fuse has blown. If it is you need a ysus PCB. Check out encompassparts.com. If you get a new board be sure to set all the controls on the new board to match the old board. If you don't you will have little sparkles all over the screen when it comes back on. I hope this helps. You may want to check all fuses on the power supply and the zsus which is on the right side of the set. I have seen both the ysus and zsus be bad together. Good luck and thanks.
Posted on Oct 24, 2009
Sony trinitron KV-32S26 While watching the tv it went POP and the picture went pop. Is the picture tube shot?
not really..maybe an overloading of the secondary power supply could create this problem..check first the horizontal stage circuit for shorted component..before suspecting the picture tube
Jul 17, 2011 | Sony Televison & Video
The picture went out, no sound nothing... There was a pop then the picture went out. its only three years old...
the popping sound is a capacitor inside burnning out. its just a case of looking for the one that has burst or bulged on top and soldering in a new one.
Nov 29, 2010 | HP PL4260N 42 in. Plasma HDTV
Picture went dead
More than likely your backlight inverter board went dead
May 30, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Total loss of picture
The snap/pop was your lamp exploding. Your users manual will give you the part# and instructions on installing it yourself.
Apr 20, 2010 | Akai PT50DL24 Television
Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Mar 22, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tv just went pop and the screen went the green is light is still on but no picture
I you eared a loud pop sir it could be that the lamp went out, and that was the pop that you eared, you can take the lamp out and check it, if it was that there is a page called Discount-Merchant.com were you can get a lot of good lamps at a very good price also.
Jan 05, 2010 | Televison & Video
Have an old sony HDTV proj tv, and the picture went out last night. I heard sort of a "pop" then no picture
Pop sound shows that some thing went wrong inside TV and most probably any part got busted.
Let me know model number of your Sony TV and does its standby red light blinking? if yes, how many times it blinks between 3 seconds interval.
Nov 30, 2009 | Televison & Video
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Pop no picture
i think the power supply went out .not cheap, parts and labor about 450
Jul 10, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 50PX5D 50 in. Plasma HDTV Logo
919 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
