Question about Ranger Communications RCI-6900F-25 CB Radio
Ranger rci 2950 will not transmit
Rci will not transmit
Mike Charette
    Genius:
  • Ranger Master
  • 1,847 Answers
Have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Posted on Feb 23, 2015
5 Related Answers
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: rci 2950 reception problem
Mannix, I have not checked skip conditions lately, but the last time I looked skip was not rolling at all so I'd be surprised to hear any australia,,,,,, Mechanic
Posted on Nov 05, 2008
bailenforcer
  • 6 Answers
SOURCE: no channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
Posted on Jan 12, 2009
Anonymous
  • 55 Answers
SOURCE: rci 2950
SOMETIMES THE SELECTOR SW GOES BAD ON THAT MODEL TRY TO SWITCH BACK AND FORTH
BETWEEN AM AND SSB PUSH IN AND QUICKLY
SWITCH BETWEEN THE 2 WITHOUT PUTTING IT INTO ETHER POSITION (I KNOW IT MAY SOUND SIMPLE)BUT IT IS WORTH A TRY IF YOU HAVE NOT TRIED IT YET........... GOOD LUCK
Posted on Feb 21, 2009
Anonymous
  • 39 Answers
SOURCE: ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
Posted on Sep 07, 2009
thndr143
  • 141 Answers
SOURCE: my rci 2950 recieve cuts in and out, but
A tuning can in the receive section of the radio is shorted.
Posted on Jan 30, 2010
Where can I get a cpu board for my ranger 2950?
get hold of ranger and they should be able to help you.
Mar 18, 2013 | Radio Communications
Ranger rci 2950 no am hash and sometimes loses lsb hash and wobbles on recieve and transmit
hmmm my money is on a cold or several cold solder points,,
start checking the legs on the PLL first...
Oct 03, 2011 | Ranger Communications RCI-6900F-25 CB...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
2950 RCI WONT TURN ON ONLY A BACKGROUND LIGHT
You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Good luck.
Feb 16, 2011 | Ranger RCI-6300F-25 CB Radio
My 2950 dont make a sound. &wont transmit it ben in storage awhile.whats wrong?
If it was working fine before storage it is most likely electrolytic capacitors. These "can" looking things that are all over the circuit board. These little cans are filled with electrolyte like a battery. If this leaks out or evaporated as they are known to do they will render useless or degrade circuit voltage and current in circuit.
Jan 23, 2011 | Ranger Communications RCI-6900F-25 CB...
My ranger 2950 wont transmit or receive sounds like a relay problem but dont no for shour can you tell me what is wrong with that radio thank you.
could be a number of different problems causing this. I would start with your microphone make sure it is working. it is responsible for transmit & recieve. next check to see if the memory battery is dead this will also cause this problem. next check the regulators in the radio to see if they are supplying voltage.next check voltages in different parts of radio to see if all stages are recieving power follow these steps and something will show up also check your switching diodes to see if they are bad the diodes responsible for x-mit & r-mit of transceiver.
Jan 04, 2011 | Ranger Communications RCI-6900F-25 CB...
I need a manual to base station CB Ranger rci-2990. Can you tell me where to download or purchase this manual. Thanks
http://www.rangerusa.com/websupport.html
http://www.worldwidedx.com/cb-band-cb-radios/18036-manual-rci-2990-a.html
you may find some help with these sites
Sep 24, 2009 | Radio Communications
No channel readout in front of radio ranger 2950
Jan 11, 2009 | Ranger Communications RCI-6900F-25 CB...
Ranger Communications RCI-6900F-25 CB Radio Logo
290 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
