Question about Casio FX991MS Scientific Calculator
26^37 mod 77 - Casio FX991MS Scientific Calculator
Posted by Ajish on
JClegend
    New Friend:
26^37 is easy to calculate anyway..
then calculate Ans/77->Floor of this=>NewAns
and 26^37-NewAns*77 you'll get the reminder
i.e mod77 of 26^37
Posted on Apr 16, 2013
How to get fly wheel off of 77 Ford F100, 351 mod, 400 block?
I had to do this on my 1988 F250, if I remember correctly:
Remove in this order:
Driveshaft, Starter, lower cover plate, transmission, torque converter.
Flywheel s/b bolted to converter.
When driveshaft is removed - plug gap in tranny output - between drive shaft and housing - to prevent fluid spillage.
When removing transmission - plug hole in converter to prevent spillage.
When handling converter hold it flywheel side down until - to avoid fluid loss.
I presume you have all the correct tools and a helper.
hope it goes well
Jan 25, 2015 | Ford Cars & Trucks
How to calculate 40 raise to power 77 in fx -991
In two parts. 40^77 is a 124-digit number, too large for the calculator to handle. But you can calculate it by separating it into (4^77)*(10^77).
Calculating 4^77 gives about 2.28*10^46. 10^77 is just that, 10^77. To multiply the two together, simply add the exponents to get 2.28*10^123.
Oct 26, 2013 | Office Equipment & Supplies
I need to solve 77=9/5c+32 on a ti-84 plus
You don't really need the calculator for this one:
77 = 9/5c + 32
-32 -32
45 = 9/5c
*5 *5
225 = 9c
*1/9 *1/9
therefore:
c = 25
Now to test that value, plug in the c value:
77=9/5(25) + 32
77=45 + 32
77=77 correct so c=25
May 26, 2011 | Texas Instruments TI-84 Plus Calculator
How to calculate 7744mod187
Take 7744 / 187 and round this number down. This would be 41, this tells us that 187 "fits" 41 times into 7744. We then take 187 * 41 which is 7667, then subtract it from the origional number so 7744 - 7667 = 77. Thus, 7744 mod 187 is 77.
Apr 04, 2011 | Casio FX-300MS Calculator
Not cooling as well as should be
THe low side should be 34 degrees f. Which is about 65psi.
May 09, 2009 | Heating & Cooling
Power jack
center point is posative....outer ring is ground...
Aug 19, 2008 | 2007 Jeep Amc
Casio FX991MS Scientific Calculator Logo
582 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
