Konica Minolta DiMAGE A1 Digital Camera Logo
J S Card Posted on Sep 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rubber eyecup for minolta A1 - Konica Minolta DiMAGE A1 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Konica Minolta Master 102,366 Answers
  • Posted on Sep 16, 2012
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442935
Points
622693
You may order the part from here.
2helpful
A1 Dimage rubber eye piece for viewfinder?
I've had the same problem. You simply can't get them new, but you can salvage them from the many scrap A1's and A2's which have suffered circuit board failures. Take care as you peel it off the old camera though as it's very easy to tear. Best reglued with a few very carefully applied smears of superglue. If you want your camera to last, then afterwards use a bit of double-sided foam based sticky pad to secure the viewfinder in the down position: leave it free to move and it WILL fail (I'm amazed it hasn't done so already). Basically there's a poor design which causes the flexible circuit board to crack and once it goes it usually cannot be repaired.
A whole scrap camera is usually quite cheap on auction websites, but ask questions to ensure that the item is supplied to you before the previous owner has harvested all the all the useful bits, such as batteries and caps.
There is an ebay seller in the USA who sells an alternative eyecup which will just about fit, but it interferes with the viewfinder's ability to lay flat and also looks very amateurishly applied afterwards. The original item is by far the best.
Hope this helps, please take a moment to rate my answer.
1helpful
Where can I get replacment eyecups for Zeiss 8x56 binoculars.
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Mar 18, 2010 • Optics
The rubbers on the eye pieces are deteriorated are they available anywhere
10helpful
Replacement parts for Tasco binoculars
1helpful
Wearing glasses with my binoculars
There are no adaptors for this problem.
The Kestrel should have rubber eyecups. They are fairly thick and stiff but these need to be folded over to be used with glasses.
If that isn't working for you you could try this. Some who wear glasses remove the eyecups. The rubber unscrews. The eyecup is then replaced with the rubber from a bicycle inner tube. Stetch the inner tube over where the eyecups were sitting. This can be cut and folded to the right height to allow viewing with your glasses.
Just removing the eyecup and using glasses may result in you scratching your glasses on the metal eyepiece.
3helpful
My Tasco model 440, 7 x 50 binoculars, 1980 vintage needs new eyecups. Where can I find replacements. Bill
2helpful
Need rubber eye cup for Konica Minolta A2 viewfinder.
These are frequently lost and are fashioned of purest unobtanium.
When mine disappeared I bought a non-working A2 on eBay very cheaply and carefully removed the old eyecup from it and glued it onto mine, it also had the benefit of providing spare body covers, a lens hood, battery and a strap. A cheaper alternative is to buy a non-original replacement, see item number 220440673814 on eBay, or search for seller birthdayboy; the eyecups he sells are good, but it looks ugly and gets in the way as it isn't flush with the back of the camera.
Don't re-sell the donor camera if you buy one: sooner or later you'll need the flexible circuit board from inside it, as the one in your camera WILL eventually fail to power the viewfinder lcd backlight. The old camera will serve to show you how to dismantle and repair your original one. It's one of those jobs which is so fiddly and time-consuming that a professional repair is totally uneconomic.
Missing an eyecup on Tasco model 109 8x16x40
2answers
Missing Minolta Binocular eyecup
LOST LEFT EYECUP FOR MINOLTA 7X35 WP.FP CONTACT ME GEORGE COLE AT [email protected] THANK YOU VERY MUCH
Oct 09, 2008 • Optics
Eyecups are sticking on my Swift ultra light binoculars
The rubber outer ring of the eyecups can be peeled off of the metal ring underneath. This exposes the three tiny screws and their channels that allow the eyecups to move in and out. Clean any debris out of the channels, tighten or replace the screws if necessary, and fit the rubber covers back onto the rings.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
