Question about Wagner Spray Tech 0515030 ProCoat 2800 PSI Airless Paint Sprayer with Swivel by Wagner
I cannot get my wagner 2800 procoat to prime it start then stop
I have just added amnew inlet valve and it still dont prime
Posted by bobby woodberry on
Will not pick up paint
Hi Dan,
Yes there is a second ball valve; it is the outlet valve located inside the piston. When you remove the inlet housing to access the inlet valve and its parts, you can partly inspect the outlet ball valve which you can see in the end of the piston; check that it is free to move and nothing is stuck in it. Another thing that can stop the sprayer from priming is the priming circuit is blocked up, either the bypass valve or the return hose or both. This happens when you don't flush this out at the end of the day.
Sep 16, 2014 | GRACO INC 210 ES Airless Sprayer
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
My procoat won't prime
The inlet valve is probably stuck. It is a flat poppet type, so you need to free it up. A Graco dealer should be able to supply a special small plastic bottle with a special top filled with their Pump Armour to do this job. Otherwise you can unscrew the inlet valve from the cup side to clean it out, but be careful not to lose the small spring. You should always flush Pump Armour through the ProCoat after use otherwise the passageways corrode
Feb 18, 2014 | Wagner Tools & Hardware - Others
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
Hotpoint wd64 washer dryer. Clothes are not being washed after cycles. very evident on whites. Seems to be running through cycles quickly. put onto c cycle. long 95deg wash. takes in water and starts very...
Hi
You'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 16, 2011 | Washing Machines
I have a Wagner Procoat That i cannot get to prime?
had the same problem i sprayed wd40 where the suction tube goes and primed three times hope this helps
Aug 27, 2011 | Garden
Wagner Spray Tech 0515030 ProCoat 2800 PSI Airless Paint Sprayer with Swivel by Wagner Logo
582 people viewed this question
Top Wagner Spray Tech Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
Tom Chichester
Are you a Wagner Spray Tech Air Tool and Compressor Expert? Answer questions, earn points and help others
