If you are running Windows Vista,
and you have the soundmax AD1888 Chipset,
you have no sound in Vista . . . relax, this problem is common.
Try the following soundmax AD1888 Drivers in this torrent.
You will find 2 maps in the downloaded file.
1) Use the swsetup, there is a setup.exe in it, install, then reboot your pc. You should have sound now.
2) If this does not correct your problem,, update your driver using device manager,
with the other map (Vista-Driver-Vista)
This has worked in nearly every instance :-)
Follow this link below to the file. Please be sure to provide appropriate feedback for me if this helped!
http://dl.torrentreactor.net/download.php?id=1827037&name=Vista-Audio+%28Soundmax+AD+1888+Drivers%29.rar
