Electrolux EW1200i Front Load Washer / Dryer Logo
Question about Electrolux EW1200i Front Load Washer / Dryer
How do I access the fault codes on an electrolux 1200
Posted by karen matthews on
Anonymous
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Posted on Sep 16, 2012
How do I get rid of code? I have an Electrolux front load dryer model #EIMED55IIWO, with E 64 error code. When initially starting the dryer I cancel the code and start the dryer.
E64 error code Electrolux dryer! E64 fault code on your home Electrolux clothes dryer. What this code stands for is that you have a shorted heating element. Other Possible fault: Heater thermostat faulty: Wiring faulty; Electronic board faulty.
https://advancedappliancesolutions.com/e64-error-code-electrolux-clothes-dryer/
https://www.youtube.com/watch?v=ErDSsjVywwg
tip
BMW Motorrad Fault Codes
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
Oter fault codes here http://bike-manual.mozello.ru/bmw-motorrad-fault-codes
on Dec 20, 2016 • Motorcycles
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
2helpful
New electrolux range, fault code F14
HI. Generally, this will be the result of a communication error. There is, possibly, a bad connection at the control panel board. This connection may be worn,or simply disconnected, slightly. Gain access to the back side of the control board, and check to make sure of proper connections at the control board. If you notice a slight separation of any connector, simply reconnect it, tightly. If there are not separated connections at the control board, replace the control board, entirely.
6helpful
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
2answers
My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
