Question about Husqvarna Huskystar 207 Sewing Machine
The motor on my huskystar 207 has seized up.
The needle broke while sewing then handwheel wouldnt turn and motor seized. I have cleaned and oiled.
Posted by wennikmom on
sylviaivie
  • Husqvarna Master
  • 1,564 Answers
Needle broke then it seized? Could be any number of things from a bent upper arm to a motor that needs servicing. I recommend you take it in for professional repair.
Posted on Sep 16, 2012
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
sewinsnap
sewinsnap
  • 135 Answers
SOURCE: where can I buy bobbins for the Huskystar 207
Visit your local Viking dealer and they will have them in stock.
Posted on Aug 19, 2010
Mary Dunn
  • 1788 Answers
SOURCE: When I was last sewing, my needle kept seizing up
What are you try to sew? If, it is heavy denim or something, sometimes the needle needs to be a heavier grade, like a 16 or 18 if that is not the problem, I think that it is your timing is causing the problem. You probably will need to take it in for service because if I am right, it is not a do it yourself job. You need the tools and expertise to fix it. Try to go to a shop that does Singer warranty work, I don't know if your machine is new but even if it isn't at least they know the machines. You can find them listed at www.singerco.com. If there isn't one near you, try to find a shop you can trust. Good luck
Posted on Nov 22, 2010
ken dourof
  • 980 Answers
SOURCE: My singer sewing machine 7430 keeps acting like
Your machine sounds like it needs retiming unless you are using a needle bigger than a size 16, I can attach instructions if you want to do it yourself.
[email protected]
Posted on Aug 08, 2011
Fairleigh
SOURCE: Husqvarna Huskystar 207 Sewing Machine not
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Posted on Sep 21, 2011
The wheel of the mashine doesnt wan to turn
And what sort of machine are you asking about ...
Nov 25, 2017 | Sewing Machines
I have acquired jones cb sewing machine.works fine except occasionally when stopped in middle of a seam wont restart but hums.will restart after turning handwheel.
Sounds like it is seizing due to old dried oil. May need a thorough cleaning and oiling. If this is the case, it would be good to avoid further use until it is repaired as continued use could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
My jones sewing machine wont stitch straight just zig zag tried moving...
Feb 01, 2017 | Sewing Machines
What could cause the motor to turn but the needle doesnt move?
it's possible that the sewing machine may need a adjustment or a part could be broken, the machine should be checked
Dec 06, 2014 | Necchi Sewing Machines
Cannot source replacement handwheel , can anyone help me source one
Have you tried http://www.sewingpartsonline.com/handwheel-viking-4123009-01.aspx ?
Apr 01, 2014 | Husqvarna Huskystar 215 Sewing Machine
Leather
check with leatherworker.net,, go to the forum and ask them
Nov 12, 2012 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine Logo
385 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
