It has 3CD drawer. Load all three CDs and try to play #1, IT WILL NOT READ I.E. n-CD flashes, tried to play #2 and #3, the same thing. How do I reset the sytem?
SOURCE: cd changer malfunction
I know that this sounds like a crazy solution to Pitsy`s CD problem but today i took a chance by using my lawn gas blower. First I opened the drawers of my CD turntable and also my cassett doors. I put ear plugs on and blasted the air into the openings. All i can say is it is now working fine !! Lou F.
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
SOURCE: cD Player returns NO DISK code
had similar problem, first things first.........clean lens with isopropyl alcohol on a Q-tip. to do this, you will have to remove cover and likely the disc tray. worked for me.
SOURCE: Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged
in) then whilst pressing down the record button and the X-BASS/DEMO
button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR
ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
