Televison & Video Logo
CHRIS BARTLETT Posted on Sep 15, 2012
Tv got picture but no sound tried all connections all ok
TV COMES ON. JUST SMALL FLICKER OF COLOUR THEN NO PICTURE BUT SOUND ON.
Anonymous
Level 1:
Habit-Forming:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 16, 2012
Anonymous
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
Helped
1047
Points
15
Hi sound like digital board gone.There is another possibility of bad connection or lost connection between main board and digital board.Hope that helps.
5 Related Answers
Anonymous
  • 487 Answers
  • Posted on Jun 21, 2008
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Anonymous
  • Posted on Jul 25, 2009
SOURCE: samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Anonymous
  • Posted on Jan 08, 2010
SOURCE: flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Anonymous
  • 8 Answers
  • Posted on Jun 02, 2010
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
1helpful
I have a LG601D plasma tv the problem is while whatching tv the picture will start to flicker off & on then no picture but still has sound what could it be
Sound without picture.
It could be the sustain board and control board problem.
Maybe Overheat or Blown.
It will need few hundreds to change them.
Will suggest to get a brand new LED LCD.
I have purchased the apple component tv cable for my ipod 5th generation but when playing back videos I have only sound - no picture. I have set the Ipod to tv out, PAL (Aust) & connected all the...
Hi, this seems to be a physical failure with your connections and not your TV input configuration (as you're able to listen to your audio). First, try to see if there's an obstruction on your iPod dock (maybe some dirt or dust) and on your AV cable. As the video travels through different pins than the USB or power, you may've not noticed the failure until now. Sony Bravia TVs are all built in the same factory, so they can easily change from NTSC and PAL, try going to your settings and change the TV out to NTSC. If everything else fails, take it to your Apple Store, they'll be more than happy to test it for you and if it's broken, replace it for a working one.
--Dennis
TV after removal of picturetube for playing music from DVDplayer
Why use the TV in hearing the sound from DVD
player. You can use some small speaker and connect it at the back of the DVD player.
LG LCD Tv has sound but no picture only colour vertical lines. Can be fixed?
If your screen has a picture in the left corner with a small square with lines on it but still has sound...try this....
unplug your TV itself from the power source, then hold down the power button on the tv itself for 1 minute, then release.... Plug the tv back in and see if the issue is resolved. I just called LG customer support and a woman walked me through this process and it fixed the issue !!!! Hope this helps..
No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
