Question about Fuji FinePix S1 Pro Digital Camera
Fujifilm s1 pro flashing rec - Fuji FinePix S1 Pro Digital Camera
Posted by cspteja on
I get an err messasge when the camera is turned on.Also I would be interested in a service for the camera. How to get it to you, and how long for return, and cost? David Plessas
If "Err" is displayed on the LCD panel on the top of the camera when the "MENU/EXE" button on the FinePix S1 Pro is pressed, check the following:
<If "Err" is not flashing>
1. If the slot cover is open, switch the camera off, close the slot cover and switch the camera back on.
2. If the remaining charge in the AA-size batteries is low, switch the camera off, replace the batteries and switch the camera back on.
3. If steps 1 and 2 above do not remedy the problem, contact the store where you purchased the camera or your nearest authorized FUJIFILM repair center.
<If "Err" is flashing>
1. Pictures cannot be taken because the remaining charge in the lithium batteries is too low or because the camera mechanism has stopped operating due to the camera being used in cold conditions.
In this event, switch the camera off, replace the batteries and then switch the camera back on. If replacing the batteries does not resolve the problem, set the focusing mode to "M" and release the shutter before switching the camera off briefly.
2. If step 1 above does not resolve the problem, contact the store where you purchased the camera or your nearest authorized FUJIFILM dealer.
Please click here to download the manual for Fuji FinePix S1Pro .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
Fuji Finepix S1000fd instruction booklet for this camera
You can download on
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s1000fd_manual_01.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Fuji FinePix S1 Pro Digital Camera
Fujifilm S1...after taking a picture, the camera will not transfer the image onto the microdrive??
First check with another Memory card. If you have the same problem with another one, remove the card, then check the card contacts inside the camera. They might not conduct properly, if you don't see anytihg out of the ordinary here, then I recomend you contact Fujifilm directly.
If the problem is on one card only, try to format it while inside the camera, then if It doesn't work try to format it on a computer.
If by doing this the card is still not working, it is certainly dead.
Hope this helps.
May 19, 2011 | Fuji FinePix S1 Pro Digital Camera
I am getting a FEE error on a Fuji FinePix S1 Pro Digital, the 300mm lens seems to be connected correctly. please help thank you.
I don't know if you have a manual fir this camera so I'm giving you a "Google" search link for a manual in PDF format. It the fourth one down.
http://www.google.ca/#hl=en&source=hp&biw=1303&bih=818&q=Fuji+S1+Pro+PDF+manual&aq=f&aqi=&aql=&oq=&fp=a5556ef3492e88b9
Okay, I've had several Fuji Pro cameras including the S5 Pro and these cameras had dual memory card slots it's listed in section 6 page 24 of this PDF manual
Okay what can happen and happened to me several times (didn't learn the first time) was that I had the camera set on the Compact Flash card and filled it up but the camera needs to be manual set for the next card it's not automatic. So I'm going to assume that the media card you are trying to write the new picture files to is full.
You can download the pictures and then format the car (in the camera) then continue or switch to the other card in the card slot. This camera used a Smart Media and a Compact Flash Card.
Cheers
Apr 12, 2011 | Fuji FinePix S1 Pro Digital Camera
Fee flashes even though apeture ring is set to
I have the same prolem. I think it has soming to do with the Meter coupling lever , it protrudes top of the Nlkon F-mount on the front of your camera. it may be need of repair
Sep 12, 2009 | Fuji FinePix S1 Pro Digital Camera
Will not take pictures fujifilm finepix s1000fd
it seems like CCD failure rush to service centre
Dec 25, 2008 | Fuji FinePix S1 Pro Digital Camera
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Jun 06, 2008 | Fuji FinePix S1 Pro Digital Camera
HELP! need to know why my Fuji FinePix S1 pro flashed "f EE" on the LCD screen?
Thia error is caused by the use of a non-AI lens, or that the F-stop is not set to the lowest setting.
If the lens can support light metering on this camera, then the solution is to set the F-stop on the lens to the smallest number (ie, 2.8, or 3 or whatever the smallest number is.)
John C. Vincent
yellowcaseartist.com
Oct 10, 2007 | Fuji FinePix S1 Pro Digital Camera
Camera shuts down when the flash is opened
the flash circuit of the camera is short. the moment you switch on the flash it drops the supply voltages of the battery. you have to show it to a repairer.
Nov 17, 2006 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
35 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Fuji Camera Expert? Answer questions, earn points and help others
