Our Cradlepoint MBR1200-CP has been operational for 2 years. Need to change some settings, but when I try and log on to the router http page 192.168.0.1, I just get a blank page. I have turned off all windows firewalls and the avast anitvirus thinking is is blocking access somehow. Tried re-boot of router, same problem.
https://cradlepoint.com/support/cradlepoint-mbr1200
links to various pdfs.
https://cradlepoint.com/sites/default/files/mbr1200_datasheet.pdf
https://cradlepoint.com/sites/default/files/mbr1200_manual.pdf
This one seems most likely to help:
https://cradlepoint.com/sites/default/files/mbr1200_qsg.pdf
does show 'http://192.168.0.1' as the browser-access URL.
Questions:
Your browser isn't putting in 'https'?
Tried multiple browsers?
Rebooted your computer ("if in doubt, reboot", esp w Windows...)?
Hmm, only place the 'CP' designation shows up is on the EOL page. Vendor is likely to be no help...
http://knowledgebase.cradlepoint.com/articles/Support/Product-End-of-Life-Policy
end of life on August 25, 2011
end of support: 04/15/2012
last firmware release: version 2.2.1 posted on April 4, 2013.
Helpful?
SOURCE: cannot configure WGXB102 with router
pl. try the following
1. do hard rest of your router i.e at the back of your router u'll see a tiny reset hole in that whole put in a ball pt. pen and press the hole hard for 10 sec. and some lights on the router should start to flash then take out the power cable for 30 secs and then again plug in the power cable and try opening the router page and do'nt add www to the address.
SOURCE: Cannot access PageScope Web Connection in client PC
first try to ping this address, to see that this pc finds printer. you have to check network settings for that pc
SOURCE: sweex router login page
i can not to my router my ip 192.168.55.1 admin/Admin nor password or gebruikisname can you help my ty
SOURCE: trying to access my 2wire router
Please try the following:
1. Check the ip address and default gateway on the computer by typing ipconfig in command prompt.
2. Try to ping the default gateway from the hardwired computer.
3. If you are able to ping the default gateway, but not able to log in, Delete Cookies and check if you could log in.
4. If you still could not log in, try from another web browser.
Open your browser and enter 192.168.0.1 in the address bar of your browser.
Entering the last 6 characters of the MAC address will get you into the Admin level of the router.
Go to the Tools tab and select 'User Login' from the menu on the left of the screen.
Find 'Require User Login' and uncheck the box. (Earlier Firmware versions will find this box under the Basic tab, click 'wireless'.
Click 'Save Settings' at the top of the page, leave this page open as we will return to it later.
Turn on the power to your Wii
Now search for an access point on the Wii consoles main menu, just click on the Wii button in the lower left hand corner.
Now click on Wii Settings
Clicking on the blue arrow on the right side will take you to a second settings screen.
Select Internet, select Connection Settings, select None, select Wireless Connection, then 'Search for an Access Point'.
The Wii should search for wireless routers within range and display a list, choose your router from the list and click OK.
If
you previously selected a security level for the router there will be a
padlock icon next to the name and you must enter the same settings in
the Wii that you entered into the Cradlepoint.
Click 'Save' and then click 'OK' but DO NOT choose OK to start a connection test!
Back on your computer, click on the Advanced tab on top and select Gaming from the menu on the left of the screen.
Under 'ADD GAME RULE' be certain that the 'Enable:' box is checked, and in the box next to 'Name:' type in "Nintendo Wii",
Next to 'TCP Ports to open:' type 80, 443, 28910, 29900, 29901, 29920 (exactly with commas)
Next to 'UDP ports to open:' type 1-65535 (exactly again). Click 'Save'
Return to your Wii and click on 'Choose OK to start a connection test'.
If you are still having difficulties (Wifi only),
Nintendo tech support has recommended changing the channel of the router
to either 1 or 11
