Question about Creative Zen Mozaic, Mosaic 8gb Mp3 Player, Fm Radio, Voice Recorder, Speaker
Zen mosaic wont work
It turns on but just flashes the logo then switches off. if i connect it to a pc then zen screen states scanning disk but does not connect. ant ideas?
Posted by sneakydave52 on
volson1957
Http://support.creative.com/kb/ShowArticle.aspx?sid=64004
this is recovery mode, worked on mine.
Posted on Jul 14, 2013
Zen player mosaic crashes re-building library (uses flash memory)
I've been having the exact same problem. No matter how often I reset it it still becomes stuck on the rebuilding screen. I was thinking I may just copy all of my music onto my computer and then do a complete reset on my Zen and copy it back but I don't want to go to all that trouble if there is an easier way to fix it.
Jan 25, 2010 | Creative Labs Creative Technology Zen MP3...
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen screen wont light up its dark i tried the light up feature but no luck
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
hope this helps you
Jul 24, 2009 | Creative Labs ZEN Stone MP3 Player
Zen nomad jukebox xtra in need of repair, any suggestions?
Look up "jazzmantim" or "Jazzman Tim" on google or ebay; he specializes in fixing and upgrading Zen's, and is competent and fair.
Mar 07, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen mosaic frozen on charging screen
Try hitting the reset button. Its the small one on the left side. You might have to push it with a pen or something,
Jan 28, 2009 | Creative Labs Creative Technology Zen MP3...
Instruction for zen mosaic by creative
I think alot of people are having the same problem I was. We got home, opened the box, plugged it in the computer, and nothing useful happened so then we installed the mini-cd. Well the thing is windows stops looking for a driver once it searches and finds nothing, and unfortunately those of us using XP do not automatically have the drivers. So...
SOLUTION
-If you have not already installed the mini-cd, do so, or download from Creative's site in the support section(if you do you might want to grab the latest firmware update)
-Once pack has been installed the drivers have been as well, BUT as I mentioned we now have to tell windows to look for them again.
-Reconnect your Mosaic
-Right click "My Computer"
-Chose "Properties"
-Click the "Hardware" tab
-Click "Device Manager"
-A window will pop up and you will see a long list with (hopefully only) one thing under the "Other Devices" sublist. It should be something along the lines of "Creative Zen Mosaic". Right click it
-Chose "Update Drivers"
-Follow prompts agreeing to search and auto install
-Once install is done, in a moment the screen on your Mosaic will say "Docked"
-Congratulations!
If you have downloaded the updated firmware this is the time to install:
-Ensure your Mosaic is in "Docked" mode
-Execute the firmware update
-Click "Upgrade"
-Wait (it takes a moment or two)
-Updater will say it is complete
-Mosaic will reboot
-Click "Close"
-Congratulations!
Hope that helps.
Dec 11, 2008 | Creative Labs Zen Touch MP3 Player
Zen m : after reset no logo appears, black screen,
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
try this
or
this
If that doesn't fix it try the USB cable
Feb 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
Disk doesn't work
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
you can replace the hard drive with a flash drive to fix this.
Feb 18, 2008 | Creative Labs Zen Micro MP3 Player
First Frozen At The Logo, Now No Screen At All
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
good luck
please mark the post with a fixya
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Cant turn it on and PC cant read it...
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Dec 31, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Mozaic, Mosaic 8gb Mp3 Player, Fm Radio, Voice Recorder, Speaker Logo
Top Creative Audio Players & Recorders Experts
Are you a Creative Audio Player and Recorder Expert? Answer questions, earn points and help others
