Question about Razor E100 Electric Scooter
How long does it take to charge Razor E100 Electric Scooter - Red
Sophie Herald
    New Friend:
Av put my scooter on charge and it’s just gone right to green dose this mean the battery is not working thanks
Posted on Oct 28, 2018
Visa Pisa
    New Friend:
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Posted on Aug 18, 2018
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Why is my razor e100 red electric scooter going so slow?
Your scooter is dying the slow death that all Razor scooter owners are suffering. See my related post on this. Anyway, here's the deal..
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Posted on May 11, 2009
Martin Dixon
  • 38 Answers
SOURCE: I need instructions on how to replace the rear
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Posted on Aug 18, 2010
Martin Dixon
  • 38 Answers
SOURCE: have an e100 razor electric scooter. it has not
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Razorbase
  • 11 Answers
SOURCE: I own a Razor E100
If you mean it flicks straight over from charging to charged then this is classic signs the E100 battery is dead & needs replacing.
Posted on Jul 05, 2011
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Dec 17, 2013 | Razor E100 Electric Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
Oct 21, 2013 | Razor E100 Electric Scooter
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
I have an e100 that appears to be fully charged. The red light on the on/off switch is on but the scooter goes nowhere? I checked the batteries for output and goes 12.85 volts. The motor doesn't even...
If thats the voltage from the 2 batteries joined together then the voltage is far too low to run an E100, sounds like one of the cells has died, must have a 24v combined output.
Jun 28, 2011 | Razor E100 Electric Scooter
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
Charges and light comes and sounds like it engages but does not move
in order for the scooter to go you must already be walking with the scooter. so hold down the throttle and start to push (kick) the scooter.
Jan 31, 2010 | Razor E100 Electric Scooters Red
E-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Jul 17, 2009 | Razor E100 Electric Scooter
Razor E100 Electric Scooter Logo
1,441 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
