Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Wiring diagram for Marathon Electric part # 130-1010, model # LQD 56B17D5539H p
1 Related Answer
thepool
thepool
  • 78 Answers
SOURCE: need wiring diagram for a marathon electric motor
Wiring diagrams for AO Smith motors are located on the side of the motor.
Posted on Apr 21, 2010
Wiring schematics for inside Z313?
Model Number: 184TBDR7324
Cat Number: Z313
Marathon Electric
Support
support
Sep 17, 2017 | Dryers
How do I wire around upper heating element until I can get an other one to replace it?
Question posted under marathon electric water heater.
Marathon is 240Volt dual element non-simultaneous water heater.
Non-simultaneous means that upper part of tank has to reach temperature before power is sent to lower thermostat and element. So if upper element is bad, then water heater has no hot water.
http://waterheatertimer.org/Replace-anode-rod.html#audibleBW
1) You need to by-pass upper element without by-passing upper thermostat.
2) You should never by-pass upper thermostat because it has ECO-reset protection.
http://waterheatertimer.org/How-water-heater-thermostats-work.html
3) Open following link for image of wiring:
http://waterheatertimer.org/images/Marathon-wiring-700.jpg
4) Take photo of your wiring in case color code is different on your specific model
5) Look at upper thermostat.
Remove yellow wire from terminal 2 on upper thermostat, and cap off temporarily.
Remove red wire from terminal 4 on upper thermostat, and move it to terminal 2 on upper thermostat.
6) For more effective operation, look at lower thermostat.
Remove black wire from lower thermostat terminal 1 and move wire to terminal 2 on lower thermostat.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem MR105245 Marathon Electric Water...
Need wiring diagram for a marathon 1/2 hp electric motor 220 to 115volt
HAVE POWER TURNED OFF AND LOCKED OUT. If the motor is a dual voltage motor it should have a wiring diagram on the motor. Check on the name plate of the motor. You should see a high and low voltage diagram. Follow the low voltage numbering. The widings need reconfigured to operate at a different voltage. Hope this helps you...Jim
Feb 12, 2011 | Craftsman Saws
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
204 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
