3 green 2 green with white stripe 2 purple 1 black 1 white 1 brown 1brown with white stripe
Don't know what you need
Open up the wire harness enough to be able to make a repair
You slide heat shrink tubing over the wire,add wire, any color
but the same wire size or gauge & solder them & then heat shrink
If only the plastic is chewed & no copper wire ,then seal with clear
nail polish & tape real tight with 3M hi temp electrical tape,home
depot has that
Then use the stretchy rubber tape to cover all repaired wires,
unless you like you heat shrink job.
You just match the wire colors & strips that isn't the question
Have the battery disconnected
SOURCE: need the colors for the oil pressure switch at the
The wiring diagram shows it to be TAN. ???
wires are same color but need to be matched rite. got everything working except cruise controll and service engin light still on
