Dell U0636 Mouse Logo
Niki Greer Posted on Sep 14, 2012
My mouse cursor keeps flying across the screen HELP
1 Related Answer
Tim Yates
  • 36 Answers
  • Posted on Jul 16, 2009
SOURCE: dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
My touchpad has ceased to work. When I use it the cursor flies all over the screen. I am using an external mouse which defeats the object of a laptop-wires etc.
this is due to some applications your cursor doesn't work or it fly over the screen automatically uncontrolled.try rebooting system when it happens.
hoping it will help u
thnx
1helpful
The cursor sticks sometimes when you move it across the screen. sometimes it want move. sometimes when you drag a file to put somewhere else, the cursor want release
replace batteries they get weak and cause mouse to act strange
replace mouse
replace mouse pad, make sure you use mouse pad
clean led light
clean mirror
I got a cheap replacement plug-in led mouse for under 9 bucks Walmart
2helpful
2answers
EA Sports Cricket 07 cheats
Cheat Codes:
Submitted by: Rishab gupta
Highlight, but do not select, the "My Cricket" option at the main menu
with the mouse pointer, then enter one of the following codes to activate
the corresponding cheat function. Press [Esc] to pause game play and
re-enter the code to disable it.
Code Effect
asif - Your bowlers have full stamina.
yousaf - Super Batsman.
afridi - You play Supersix.
salman - You play Super Four.
wasim - You have super bowlers.
waqar - You bowl superballs.
rhodes - You have super fielders.
inzamam - Your batsmen have full stamina.
akhter - Your bowler bowls with super speed.
haier - Empire does not give noball despite.
malik - Fielders have some enough flying abilities to catch the bowl.
gul - Your bowler always has all special deliveries.
saqlain - Your bowlers bowl with magic moves.
razzaq - Faster runners.
rkobat - Super batsman.
rkosix - Super Six.
rkopowerbowl - Super bowler.
rkofly - Flying fielder.
rkosd - Special deliveries.
rkoall - All rk code effects.
Full Stamina:
Enter "ASIF" at MAINMENU by keeping your mouse cursor at "MY CRICKET" Option
(Nether enter Nor click), Play & You will observe that your BOWLERS always
have 100% stamina. Enter "INZAMAM" (WITHOUT "") at MAINMENU by keeping your
mouse cursor at "MY CRICKET" Option (Nether enter Nor click),Play & you will
see that Your BATSMEN always have FULL Stamina.
Super Speed:
Enter "AKHTER" (WITHOUT "") at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option (Nether enter Nor click), Play,Bowl with Fast or Fast Madium or Medium Pace
Bowler (No Spinner) & You will observe that You bowler bowl with Super speed which
has never been seen before & may be equal to 200 Km/h or greator. By using this cheat,
you can out your opponents very easily except PAKISTAN TEAM.
Empire Quitness:
Enter "HAIER" (WITHOUT "") at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option (Nether enter Nor click),Play,Bowl & You will observe that Empire don't give
NOBALL despite parameter of your Bowler,s SpeedMeter reaches in RED ZONE,so in this
way, you can increase your bowler's speed but not equal to 200 Km/h or greator.
Fly Mode:
Enter "MALIK" (WITHOUT "") at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option (Nether enter Nor click)& While playing you will observe that your fielders
have some enough Flying abblities to catch the bowl. In AUTO FIELDING,Press [Shift]
key to fly your Fielder chasing the ball.
Special Deliveries:
Enter "GUL" (WITHOUT "") at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option (Nether enter Nor click),Play,Bowl & you will see that your Bowler always
has all Special Deliveries.
Magic Move:
Enter "SAQLAIN" (WITHOUT "") at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option(Nether enter Nor click),Paly,Bowl & you will see that your (All kind of) bowlers
bowl with magic move.
Fast Running:
Enter "RAZZAQ" (WITHOUT "")at MAINMENU by keeping your mouse cursor at "MY CRICKET"
Option(Nether enter Nor click) & You will see that your runners run so fast such as
a HORSE.
Note:
These all above cheats work in any difficulty. These Cheats can be deactivated by
re-enter at PAUSE MODE(Press "ESC" While Playing) but cann't be avtivated at PAUSE
MODE,To do this, You will have to perform above Method.Play & Enjoy.
General strategies:
Submitted by: BoneK
* You can make batsman out by bowling with a slow medium bowler and bowling shot of
the length bowl (slower delivery).
* With fast bowler you can bowl the good length bowl. The keeper will have no problems
catching it. Keep the speed to almost full, but not full. Also, any swing will do.
* Play Straight and hit the Six hit shot only when the bowl is near your half crease
length or else see your stump flying towards the keeper.
2answers
Dell latitude d820 xp: Mouse inputs are moving
Hit sixes and fours in all the balls.
Cricket 2007
This game is titled also "Cricket 07"
Cheat Codes:
Code Effect
rkosix - Super Six.
Full Stamina:
Super Speed:
Empire Quitness:
Fly Mode:
Special Deliveries:
Magic Move:
Fast Running:
a HORSE.
Note:
General strategies:
Submitted by: BoneK
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
My cursor keeps freezing and I cannot drag it across the screen. I have to shake it and it takes several times to do this. I have a pc/2 compatible mouse. Do you know what is causing the problem. When...
You may have broken a solder connector in the mouse when shaking it. Try a different mouse, if it doesn't happen with the new mouse you know the old on is the problem.
1helpful
Cursor drift
don't us the optic mouse with the roller mouse pad. what is happening here, is the optic trying locate a point. since the pad is not flat and smooth. the optic is doing search (meaning it is constantly looking for a landing point). since it can't fine one, it will draft.
hope that will help
My cursor slides off of the screen (by itself) when I click & drag!
Seems there is something internally wrong in your mouse or you use the mouse on a very strange material base. I have heard that optical mouses can have strange behavior when used on glass tables or thick woolen carpets, a mouse pad would solve it. If that does not work and it's still under warranty, just ask for replacement or repair.
2helpful
2answers
Sticking cursor
these type of problems can be caused by a wire crossing the line of sight between the mouse and the receiver check
you have no cables in the middle of them even a usb cable can cause it to respond this way
also spyware and viral activity does this to
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
