I need to find the sata drivers for this hard drive that I can download to a flash drive and install with a clean copy of windows xp
SOURCE: Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
SOURCE: Installing a second sata hdd
have you check the jumper setting in the drive and the connect it to slot 2 not the slot no 1
SOURCE: mine hitachi hard disk is
If you are running more than 2GB of memory it will not copy OS properly. If you have more than one HD in the computer go into BIOS and in Boot select the correct HD for booting at the top of the list. Sometimes disconnecting other HD helps if any of them already have a MBR (Master Boot Record) installed which will confuse the setup program.
In setup be sure to use the Format option. If you don't there will be multiple failed OS corrupting the new install. Full Formatting will remove any possible virus infections. A quick format will only partially remove the old files and may not remove a virus if there is on on the drive. (a quick format only removes the old file headers allowing the space to be reused for the new files. Old files not written over can still hide the virus)
Testimonial: "thanks for giving good suggession "
SOURCE: Trying to install Hitachi Deskstar
Can you look in the bios and see if your motherboard is configured to use your SATA drives in AHCI mode or to emulate IDE mode?
