The design 200 is a direct drive beltless model with a coupler mounted between the motor and transmission. Over time that coupler can break causing the tub not to spin. If the coupler is ok then the transmission itself or the basket drive could have a problem. I recently worked on a design 2000 direct drive washer and did a home movie.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Washer spin cylcle leaves clothes wet
Mine did the same thing. Solution. I took it back to the store where I got it. Fortunate for me they gave me my money back. Now I am looking for another one. What a nightmare. There is nothing that has a consistently good recommendation except Miele. Where I live they are not available. Well!! We could always go back to the scrub board. je
SOURCE: kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
SOURCE: washer doesn,t spin
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
SOURCE: I have a Kenmore 3.5 washer model # 44152. The
Is your pump clear? Nothing is in the pump blocking it? Does it drain ok? Check out your pump buy removing the bottom panel..Then check you drain hose where ever it is draining into, make sure drain isnt tp far into drain, or sink becausewater will syphen back into washer...try checking these simple checks first. i think your pump has a screw in type plastic cap. unscrew and check if you have anything in it and nothing is restricting the inpeller. spin the impeller with you finger make sure it spins around freely. you will feel some tension from the magnitation it is getting. but yeah, try these simple checks first and see what happens....
