Had loose power wire ,was cutting in and out then stop working,power still at machine
There is a resettable breaker inside the machine that cuts off power to the plasmahead when tripped. Check that and make sure the head is secore to cable and cable is secure to machine.
If it still fails to function check the coil in the contactor to make sure it has not burned out. Also check the pressure switch to make sure it closes contacts to make the circuit when the unit is pressurized If switch is not functional the head will not operate. Also check gas solenoid or solenoids to make sure they do not have burned out coils as well. An Ohmmeter should show about 2000 ohms give or take some. The main contactor winding also. It may be the main contactor needs replacement- a loose power connection can lead to burned contacts. So if you hear the machine click when you press the trigger, but no power to head, and all the other items mentioned still leaves you with no power at the head, that main contactor is the likely culprit.
If IGBT's had failed- they would blow apart part of their plastic case.So a quick visual is usually adequate for those.
Posted on Sep 27, 2012
Jan 02, 2015 | Washing Machines
Dec 18, 2014 | Thermal Dynamics CUTMASTER 81 Air Plasma...
Aug 22, 2014 | GE Monogram ZDI15C Automatic Icemaker
Jan 25, 2013 | Singer 7469Q - Confidence Quilter Machine
Oct 12, 2011 | Hotpoint WMA31 Front Load Washer
Jun 22, 2011 | GE DCVH515EFWW Electric Dryer
Jan 12, 2011 | Whirlpool Washing Machines
Aug 21, 2009 | Breville ESP8XL Espresso Machine
Mar 04, 2009 | Welding Tools
272 people viewed this question
