Question about Pride Mobility Revo 3 Wheel Scooter
My Pride Revo Mobility scooter needs a new gear box.
Shoppers Home Healthcare, who took 3 mo. to find me new keys, 2 new batteries, and a new electric brake just returned it to me, and after a 10 min. drive, my scooter broke down completely. Now they are asksing another $565 for a new gear box. Could the first repair have caused my broken gear box. Can I get this fixed for way less?
Posted by ajpakvis on
patricia perrin
    New Friend:
  • 9 Answers
Never said how old it is,cant give you a good answer without knowing.
Posted on Feb 04, 2013
What are the POST codes for a revo power scooter
Go to my app and look up Flash codes for Pride Revo. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 15, 2014 | Electric Mobility Mobility Electric Power...
How do i remove the battery cover on revo scooter ?
Lift the seat off and lift the lightly velcroed back bodywork off.
May 04, 2014 | Pride Mobility Revo 3 Wheel Electric...
I lost the key and a locksmith told me that he couldnt make anoyther one. Is there a way to order a new one?
Any Pride Mobility dealer or repair centre can supply keys for your scooter, but probably won't be cheap. Have a search for Healthcare Distribution Direct and send them an email.
Sep 25, 2013 | Pride Value Line Revo Scooter 3 Wheel
Scooter wiring diagram
Bad connections on the battery posts is most likely. If the circuit breaker was bad you'd get nothing at the battery . The charger voltage is 29 volts when not connected to the batteries. 26 or more when connected and on.
Jun 30, 2013 | Pride Mobility Revo 3 Wheel Electric...
How in the sam hill do I connect the rear end to the platform of the scooter. There must be an easy way to do it. Please tell me
this is the owners manual and it will tell you everything you need to know
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Revo_om.pdf
all pride mobility scooters manuals can be found here: http://www.pridemobility.com/international/UK/ukownersmanuals.asp
Apr 05, 2013 | Pride Mobility Revo 3 Wheel Electric...
I cannot ope the battery compartment
The battery boxes are removed from the scooter by lifting the handle and pulling straight up on the box. You may have to tug or wiggle it to get it free.
Turn the battery box over and look for 7 recesses in the bottom of the box where the 7 phillips head screws are located. Remove the 7 screws and the box will come open. A long handle #1 phillips or long handle #2 phillips screwdriver should work.
Turn the box over right side up before removing the top cover. The battery connections are red to positive (+), black to negative (-). Hope this helps.
Jan 30, 2011 | Pride Mobility Revo 3 Wheel Electric...
Sticking in and out of gear
Hi. When you say in and out of gear, does it free-wheel or just not drive? The jerking could be caused by faulty motor brushes. Fitting new brushes or getting the motor overhauled would probably fix this.
If you gave a better description of the fault, we might be able to give you a better solution. good luck. Neil.
Feb 10, 2010 | Pride Value Line Revo Scooter 3 Wheel
Need wirirng diagram for batteries, pride revo
hi,
look at page 25, it contains a basic layout for the batteries.
http://www.pridemobility.co.uk/docs/UK_Revo_om.pdf
Please vote if this helps.
Regards
GeWiz.
Jan 05, 2010 | Pride Mobility Revo 3 Wheel Electric...
Pride Mobility Revo 3 Wheel Scooter Logo
366 people viewed this question
Top Pride Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Jeff Bird
Tom Chichester
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
