I keep getting this Error code E00000-0010, I need to reset the copier, but how do I do that? I am supposed to go to a back up mode to reset it but how do I do that? Please help!
This is the standard proceedure for the Canon ImageRunner Copiers and all that I'm sure will follow: Press the " Additional Function " key, then press " 2 & 8" at the same time, then the " Addtional Function " key again. You should now see the service mode screen. Press " COPIER ", then " FUNCTION, " then " CLEAR, " then " ERR ", then " OK. " This will clear the code out of the copier's memory. Please be careful in service mode becuase you can do very distructive things in this mode that may take a Canon qualified technician a long time to resolve. Power down the copier at the main power switch, wait a few seconds then turn the copier back on. If the error comes back then you have a fixing assembly problem that will have to be resolved before being able to use the copier. Good Luck.
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
SOURCE: 5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
