Question about Metra Ford F 150 Truck 1999
1999 Ford F150 4x4 has a pulsating roar in the rear end.
Sounds like bad tires, but i jacked it up an put it in drive. Still makes the noise. Anyone know if this is likely the U-joint, differenial, or maybe the drive shaft? Thanks.
Posted by Kevin W. on
Larry Green
    New Friend:
  • 32 Answers
Almost certainly wheel bearings. They really roar if they become pitted.
LPG
Posted on Sep 13, 2012
What does it mean when you hear a recurring roaring noise coming from one of the rear side of a vehicle
jack up left rear and try to jiggle tire.if there is play could be wheel bearing.remove tire and check brake shoe/pad for wear.also check if exhaust is rubbing anywhere.bad rear speaker?lion hiding in backseat?lol
Feb 25, 2015 | Cars & Trucks
Whats making my 1999 mercury sable make a loud roaring sound while driving? and sometimes it stalls when stopping or slowing down.
Used tires sometimes are used for a reason. Also make sure your brakes are releasing completely (especially the emergency brake)...sometimes over-tightening wheels on to the disc brakes can cause excessive noise.
Feb 02, 2015 | 1999 Mercury Sable
FORD FOCUS IS MAKING A RUMBLING SOUND WHEN DRIVING ONLY,
Sounds like either a bad tire or wheel bearing. Check you tires for rough spots or high/low spots and replace if belts are broken. This is a raised area on the tire that will run diagonally across your tire. If tires look OK try moving the front tonthe back and see if the noise moves. To check for a front wheel bearing drive about 50 kms per hour and slowly turn the wheels left and right. If the noise gets worse or louder you need a bearing. For the back younhave to raise the rear and pin the wheels by hand and listen for a roar.
Jul 18, 2014 | 2009 Ford Focus
Roaring in rear end at all speeds
sounds like a bearing is bad best way to find out which one is to lift the tires off the ground and put the car in drive.. u will hear which side when you inspect it
Mar 17, 2011 | 1999 Dodge Ram
Our 1999 ford taurus started making a load roaring or howling noise. We told that it was the power steering pump. We changed that ,but the roar is still there. It makes the noise at about 45mph. When...
Hi,It sounds like a noisey wheel bearing.you can check this by driving the car at 45 turn your steering wheel slighty to the left and back to the right.Listen for the howling noise to change,if it does you have one or both bad front wheel bearings.chances are thay both are bad.One's just louder than the other.if you are on a tight budget you can check them out by jacking your car up and put it on jack stands(safty first).Remove your wheels,brake pads and calipers,be sure to secure the calipers up out of the way.Remove the rotors.With everything out of the way now you can check the wheel bearings.You spin the wheel bearing slowly with the wheel stud this shuld turn smoothly,if you feel anything when turning it,then it is bad and it will need to be replaced.If you have any more questions just comment back and i'll answer. I hope this helps,if it does please rate my answer.Thank You for using fixya.....iluv2fish.........Ray.......
Jul 02, 2010 | 1999 Ford Taurus
Roaring noise front end
it sounds like a bad hub bearing
try raising the front end off of the ground and spin the tires by hand and feel for roughness in the hubs
Jun 16, 2009 | Honda del Sol Cars & Trucks
Makes a low roaring noise when you are at crusing speed.
One of the front wheel bearings are bad. Jack it up and see if one is loose, the noise will usually change if you swerve back and forth while driving. Could also be a rear pinion bearing in the rear axle.
Dec 24, 2008 | 2003 Chevrolet Avalanche
Loud roaring noise
jack up front of car get hold of tyre an see if u get any play if u do u may get away with nipping them up a bit
Nov 19, 2008 | 1999 Mitsubishi Galant
Metra Ford F 150 Truck 1999 Logo
263 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
