Question about Samsung SAMSUNG SCX6555N LASER COPY/PRINT/SCAN/NET SCX6555N Printer
Samsung scx6555n showing error #31-007
Display screen shows imaging unit error #31-007 replace with a new one, have replaced imaging unit but hasn't resolved issue, have looked in the service manual but the error code is'nt in there?
guest
    New Friend:
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Posted on Apr 06, 2013
  • guest Apr 06, 2013
  • Anonymous Aug 31, 2018
    O problema esta no aterramento que fica em cima da unidade de imagem que esta fixado na maquina, s? soltar a tampa frontal que voc? encontra o aterramento.
5 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
Posted on Jan 11, 2009
picipolman
Alex Pitoc
  • 9 Answers
SOURCE: Replace imaging unit error i
Finaly got it.
Pull out the four toner cartridges and also the drum unit , staying in front of the printer , on the right side of the drum unit, you will find a small box with two contacts.
You need to solder a 63ma ( worked for me) fuse in paralel with two rezistors that it contains. It is hold by a small klipp - it is easy to get it out. You also need to empty the waste toner behind the opc , drum or watever you call it . Restart the printer after putting alltogether.
The second solution is to buy a new one but its price talk for itself - close to a new printer :-)
Good luck.
Posted on Jan 27, 2011
komguy
Craig Gillette
  • 2306 Answers
SOURCE: how do I replace the imaging unit in my clx3160fn?
The imaging unit is that whole assembly that the toners are plugged into inside the front door of your machine. It a consumable unit available at many office supply stores. The instructions to replace the unit are packed inside the box with the new unit.
Posted on Jun 23, 2009
PrintDocta
  • 217 Answers
SOURCE: Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Posted on Jan 12, 2008
henryher
  • 18 Answers
SOURCE: Invalid Imaging Unit and Toners
Sorry about my last post. I didn't realize that it would be placed unter solutions. BUT I did get a resolution from Samsung. They passed me to the advanced team and they suggested I use a special code they gave me to reset all the machine. As I said before the machine was giving me an error that all the toners and the imaging unit were invalid. Samsung said to try this and if it didn't work they would send me a new (refurb) unit. They said to press in sequence <menu><#><1><9><3><start (b&w)> then when the unit cycles it will ask to imput the country, in my case I entered the US. The machine will then reset itself and all the cartridges and imaging unit should be reset to work. IT WORKED!! The machine said to wait while it re-installs the toners. When it did the red warning light turned off and the printer is working great. Hope this helps.
Posted on Aug 18, 2008
I have samsung C430W printer..I replace the transfer imaging unit but still it showing to replace it..how can I reset the page count of transfer imaging unit...please help...
1, I have samsung C430W printer..I replace the transfer imaging unit but still it showing to replace it..how can I reset the page count of transfer imaging unit...please help...
2, Turn Off the Samsung C430W printer using its Power button or disconnect the power cord from the back of the device and also from the wall outlet. Else, turn Off the switch present near the socket. Wait for about a minute. Replug the cord between the printer and the outlet. Power On the device and verify if the problem is solved.
3, To reset the page count, Click the Reset Fuser Life button and then choose the OK button, this resets the fuser. If the error is not rectified, the imaging unit has to be reinstalled or replace it with a new one again.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Oct 09, 2018 | Samsung Office Equipment & Supplies
Samsung lcd tv, no pic but flashlight shows image on screen. Model number un50eh5000fxza
it is a led tv you have problem with led back light strip it is need to replace with a new one (open a display and replace it)
Mar 11, 2017 | Samsung Televison & Video
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
KM Bizhub c353 touch screen
replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 20, 2014 | Konica Minolta Bizhub C353 Copier
Replaced the K imaging unit. The new unit does not reflect it being replaced on the copier. Consumables screen shows the K unit at empty still.
"K" is refereeing to the black toner not being full.... I would replace the Black toner bottle. The toners do have a chip on them, you may have got a defective one..... Good Luck
Jan 08, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Samsung 793S (Black) 17
On these older CRT monitors when you have that type of problem it indicated that the high voltage power supply is not putting out the right voltage to charge the picture tube. As the power supply gets weaker the time to show a picture will take longer and longer. It is not worth repairing the unit because parts will run much more than a replacement monitor.
Jul 19, 2012 | Samsung 793S 17" CRT Monitor
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Minolta Magicolor 3300 Imaging unit
I had the same problem. Check out page 3-308 of this document.
Take off the side cover and re-engage the gear. Should solve the problem.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
Oct 23, 2008 | Minolta magicolor 3300 Laser Printer
Samsung  SAMSUNG SCX6555N LASER COPY/PRINT/SCAN/NET  SCX6555N Printer Logo
3,864 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
