What is the process for unlocking Philips HTS3541 to all regions? thanks!
Here's what you can do when you have a Blu-ray disc with a different region code than your Blu-ray player: create a region free copy of the disc using a program named Leawo Blu-ray Copy. You can give this a shot if you fail to unlock your Blu-ray player. Here's how: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
SOURCE: the region is 4 and would like to watch all
Try this:
Switch player on
Press eject on the remote to open tray
On the remote, press 9,9,9,9 then 0
Region:0 should appear on the screen
Switch player off, then on again
Should now be multi-region
Credit goes to rimcius from www.videohelp.com
