Question about Archos Internet Media Tablet MP3 Player
Mi archos 101 g9 prende pero no prende la pantalla
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
Mi tv mitsubishi presenta falla al momento de ver una entrada ya sea digital ..hdmi o rca se miran rayas purpuras de lado a lado alguien me puede ayudar
Tengo un Mitsubishi 73 inch el prende pero no se ve nada en la pantalla pero se oye despues de 5 minuto prende la bombilla roja y no se ve nada ni se oye
Mar 18, 2014 | Mitsubishi WD-62525 62" Rear Projection...
Desarme mi dvd portatil por apretar un tornillo y ahora ya no se ve en la pantalla
vendo mi dvd player solo no funciona con el control pero se puede arregla
Sep 05, 2012 | Supersonic SC-299TDVD
Reparation de tablet archos 101 8gb
Please give details about your problem in English.Click the link below :----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 27, 2012 | Toshiba Satellite Computers & Internet
Mi n-97 no enciende para nada y no se como solucionar mi problema
Hola estaba usando mi nokia n 97 y se apago y n prendio mas lo enchufo para cargar todo y prende la lucesita como que esta cargando pero la pantalla no hace nada
Sep 05, 2011 | Nokia N97 Cell Phone
Hola tengo un freestar 2004 de repente se prende es foco de la caja de velocidades que puedo hacer gracias
hola tengo una free star 2006 y paso el swiche y no hace nada .prende el tablero y todo el equipo pero paso la llave y nada
Apr 30, 2011 | 2004 Ford Freestar
Hola mi nombre es christian, yo tengo un pioneer DEH-P7900BT y cuando lo conecto solo prende las luces de los botones pero la pantalla no, no se si esta mal conectado o el stereo no cirva. por favor...
Esto no es una solucion, pero la misma cosa esta pasando a mi. Estava trabajando, pero en un momentito se cebro.
pienso que tu radio no cirva. La misma cosa esta pasando a otros dos personas en estos forums.
my espanol es muy mal.
Dec 08, 2009 | Pioneer DEH-P7900BT CD Player
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
110 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
