Question about 3Com SuperStack 3 3300 TM Networking Switch
3Com SuperStack 3 3300 - 3Com SuperStack 3 3300 TM Networking Switch
2 Related Answers
Anonymous
  • 17 Answers
SOURCE: I want to know the
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Posted on Jul 18, 2011
rech gred
  • 9 Answers
SOURCE: 3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Posted on Apr 12, 2012
1helpful
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Bought a replacement for a failed unit. Don't know how to enter the IP and other info to get the unit started. (3com 3c8201c)
If you donot have the default IP of the router, try setting an IP as 192.168.1.2 on your machine & access 192.168.1.1 (which is supposed to be the default IP of the router)
Routing problem
The last part of the IP address has to be more than 10 apart. That is to say: if your first address is 193.156.36.90 then your second should be 193.156.36.100 or higher or 193.156.36.80 or lower. I like to go for 50 higher or lower then you are well out of the range of your main router.
Doesn't POST
I've got a Superstack II 3300 24port switch, all leds are on, and led 8 blinks.
I'll let you know if I find a solution.
3COM network switch access problem
You Could check to see if it has a passowrd and username as 3com or user as username or password thats wat mine is and i forget my pass
3Com SuperStack II 1100 - need new fans
All yo need to know is the physical size, the voltage and current.
They are usually on the little round label. Voltage is probably DC 12v, and the current should be something like 0.5 amp or 500mA, or 215mA or something similar.
Then just you will know which one you need.
2answers
How to solve the Power On Self Test in 3Com 610 Switch
This is the problem with power adopter. Please replace you adopter and let me know...
Rajeev
3Com SuperStack 3 3300 TM Networking Switch Logo
Top 3Com Computers & Internet Experts
Mike
Prashant M
Prashant M
Steve Sweetleaf
Steve Sweetleaf
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
