Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
Posted on Sep 12, 2012
My Casio Privia PX-330BK Keyboard won't turn on.
I walked into my room today, and I turned on my Keyboard and I didn't turn on. It was working fine yesterday.
Teryn J. Bird
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 14, 2012
Teryn J. Bird
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
3927
Points
17
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
5 Related Answers
Michial Gueffroy
  • 1140 Answers
  • Posted on Jan 21, 2010
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Fred Yearian
  • 5603 Answers
  • Posted on Dec 01, 2009
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Fred Yearian
  • 5603 Answers
  • Posted on Dec 10, 2009
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Fred Yearian
  • 5603 Answers
  • Posted on Jan 26, 2010
SOURCE: Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Fred Yearian
  • 5603 Answers
  • Posted on Apr 27, 2010
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
ā€¢ Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
ā€¢ If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Check the midi channel. It needs to sync to FL Studio. Channel settings you'll need to look up in the privia manual...can be laborious - but worth it in the end :)
Casio px-330bk keys pitch sharp top half of keyboard
The problem you're encountering is actually a feature, called stretch tuning. While real pianos are tuned in this way it's meant to sympathise with their natural 'organics' and might sound wrong on a digital instrument. The solution is to turn stretch tuning off. The manual should be able to tell you how.
Is there an internal reset for my privia 330?
to do a factory reset you Turn the Keyboard off the press and HOLD TONE AND FUNCTION and power the keyboard on while holding them buttons. if you did it right you'll see some wierd start up and flashes and then everything will be back to normal. try a few times if at first it doesn't work. somtimes it's picky.
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
1helpful
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
