Toshiba 57H81 57" Rear Projection Television Logo
Question about Toshiba 57H81 57" Rear Projection Television
People seem to have an aura
Best way to discribe is like watching a sports event on a foggy day... the picture is not that bright and seems like people have a white aura arond them. could this be a problem with the screen?
  • Anonymous Sep 14, 2012
    ty for the advice guys but i onlt needed to clean the mirrors and lenses
Jose Garcia
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
The problem on your tv is the convergence ic , this parts need to be replace is not an easy fix , you need to hire a tv tech normal cost about $200
Posted on Sep 12, 2012
3 Related Answers
Anonymous
SOURCE: Picture (video) jumps from bright to dim
I figured it out myself. R243 was intermittently open. Replaced it, and now we can watch the Super Bowl.
Posted on Jan 29, 2009
Anonymous
  • 150 Answers
SOURCE: PICTURE PROBLEM(white hazy picture)
hi, symptom is caused by mis-adjusted focus, theres mechanical adjustment on lenses, and theres electrical on focus block, if tv was recently moved I would guess it`s mechanical, I strongly recommend you get a tech to do this, good luck video-tek.
Posted on Jun 02, 2009
Anonymous
SOURCE: Picture seems to be quite dark when watching
Turn ALS off. IT is in the same menu as brightness.
Posted on Feb 05, 2010
1helpful
My headlights keep burning out, both bright and normal. They seem to be shorting out and it's getting expensive. Right after I replace one, the other one burns out! My lens covers are also no longer clear,...
If both lenses are foggy chances are your bulbs are acting like fuses and when wet/damp blowing,reseal with silicon,or replace lenses.(when lenses get foggy it is also a sign that the chrome has oxidised.)
1helpful
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Water damege
That depens if the fog is inside or outside, outside it usually dries faster than inside. You are advised to let it dry at least another 24 hours , if the lens is still foggy after that , thab you must go to a repair shop to let it be cleaned.
Clicking sound
Time to change speakers speaker coils burnt
Vertical
Hi. Im not at all familiar with your make of TV set, I am in the UK we dont have RCA make of TV. But what you are discribing is an East/West fault this is a common problem on all TV sets. It could be quite a few things that can cause this eg (make adjustments in engineers mode, E/W coil burnt up, Resistors or caps burnt up) Its not an easy repair for a novice to tackle It requires fault finding & being able to read A meter. Usually not exspensive to put right by A shop.
Pinkish /whitish ring
Foggy lens! It needs cleaning or buffing.. you have to open the unit to be able to clean it, thats the setback of fixed lens cameras!
Picture looks whited-out
try to put only one input directly to ur unit using also the HD input, if the pictures is good, that means your switcher is ur culprit
1helpful
2answers
Picture - Flickers/Shimmers
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
