Canon LASER SHOT LBP-2900 Printer Logo
Posted on Sep 12, 2012
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
CARTRIDGE IS REFILLED WITH TONER INK. AND IT IS PRINTING BLANK. PLS HELP. SOME INK PATCHES CAME.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1215
Points
Canon 2900 printer first time refilling completed but print not coming wht is problem
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 27, 2008
SOURCE: CANON I550 PRINTER
Remove all cartridges. Snap the printhead lever on the right side of the cartridges down. Tilt forward, lift out printhead.  Rinse thoroughly in running water until the water runs clear. Submerge in distilled water and leave for an hour. Remove, shake out and dry thoroughly with a hair dryer on warm only (not hot). Replace printhead.  Run printhead cleaning routine three or four times.
John K
  • 12 Answers
  • Posted on Jan 21, 2009
SOURCE: Printing blank pages, cannot detect any problems in maintenance
Sounds like your printhead is clogged, see posts in my profile for clearing out stubborn clogs.
Anonymous
  • 84 Answers
  • Posted on Jun 03, 2009
SOURCE: Cannon S200Spx prints blank pages
The problem is likely to come from your printer settings in your printer properties dialog box. Right-click the printer icon and select Properties. You will see within the dialog where to set the printer to print on black only and then appropriate. restart your pc and then try sending to printer again. Good luck
Anonymous
  • Posted on Sep 02, 2009
SOURCE: how to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
JM Alvis
  • 164 Answers
  • Posted on Feb 07, 2010
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
3answers
How can i fix my canon 2320 which prints a blank page yet there is enough toner?
Please double check that the nozzle of your printer is clean. Also, please run test prints with different document to check for any change to the issue afterwards.
And you'll want to restart both your printing source (ie computer) as well as your printer before attempting another test.
Also, please check that toner that you're using isn't a 3rd party toner as printer companies have updated their software to block these from working with your printer.
Thank you.
2answers
My hp laserjet printer 3055 printing out put is blank sheet is coming
This can be caused by a number of reasons however it is mostly caused by the toner cartridge missing a small spring on one end. Try replacing toner cartridge first.
How to refill canon lbp 2900 printer
IF you mean that your toner is getting low most super stores carry the replacement toner for your printer. Its always best to replace the toner cartridge then to try to get the cartridge refilled. And try to replace it with a Canon certified cartridge especially if the printer is under warrenty.
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
My printer isn't printing ink. I refilled the
the life or ur cartridge is over... its unable to make any contact with the printing circuit, a cartiadge can only be refilled 2ce or 3ce not more than that :(
1helpful
Black ink won't print
check printer preferences and settings.
6helpful
3answers
My printer lbp 2900 producing blank out put
my canon laser shot LBP 2900 gives blank paper after refilling of cartreage
Check that the cartridges are seated correctly. Also clean the contacts in the casing that the copper portion of the cartridge sits against.
10helpful
4answers
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
1helpful
2answers
Printer printing blank pages
Hello everybody. Try this :
Go to the printer properties by right clicking the default printer icon on Printer & Faxes in the Control Panel.
Go to Advanced Options and select the option that reads "Print Directly to the Printer."
It worked for me :p . the printer was not printing from Word and other programs but was printing test pages ok and the ink cartridges are new.
old marine
old marine
ZJ Limited
ZJ Limited
