Samsung CLP-510 Laser Printer Logo
debbie Quinn Posted on Sep 12, 2012
Machine says Internal error TSKUBS 0864 - Samsung CLP-510 Laser Printer
How do I add Boot devices to Boot Menu on Acer V5-122P which only shows the internal HDD
Because this is one of the thin client laptops all you have in the laptop is a Hard drive. and other boot device is a USB device that you plug in. As such the bios will not show it until it is plugged in and then you can select it to boot from.
This model is intregated with windows 8 you may boot other devices by enabling legacy mode but during this your original boot manager may removed after that you not be able to boot previous windows
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
3helpful
2answers
UNABLE TO INIT
Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
1helpful
It says "unable to clean"
5helpful
Completed instruction to set Purge counter to zero. Done. Hasnt solved the problem. Machine stil reports "Unable to Clean" & "Machine Error 48" How do I empty the "Ink...
Error 46 what is it
Here is the answer to your MFC code 46
7helpful
2answers
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
13helpful
Machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Carry on printing !!
thanks.
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
