Computers & Internet Logo
Posted on Sep 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have dell studio 1609, whenever i insert the disc, it gets ejcted itself. can i get any help?
Anonymous
Level 2:
Novelist:
  • Expert 155 Answers
  • Posted on Sep 13, 2012
Anonymous
Expert
Level 2:
Novelist:
Answers
155
Questions
0
Helped
33588
Points
491
Hi, I think the issue is with your DVD Drive (Hardware issue). Anyway we can try once.
Go to RUN (Start+R) and type DEVMGMT.MSC, press Enter. You will get Device Manager window. Here you can find DVD/CD Drivers. Expand that and you will get the full name of you DVD Driver here. Right click on that full name and select Uninstall. Confirm with clicking on OK and reboot your Laptop. Once restarted try to insert one New CD/DVD and check the status.
Try the above solution and get back with your status.
Regards,
Sreerag.S
3 Related Answers
Anonymous
  • 255 Answers
  • Posted on Jun 28, 2009
SOURCE: Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Anonymous
  • 129 Answers
  • Posted on Mar 06, 2010
SOURCE: Can the dell 17 studio accept a mini disc from my
hi,
Normally when you insert a mini cd in the drive it should work!!
but there are cases which it didn't work --- any way no problem for lap...
hope u be successful...........
Anonymous
  • 83 Answers
  • Posted on Sep 12, 2010
SOURCE: whenever I insert discs into
May be some time some drivers got missing or corrupted. Try to uninstall the drivers of your Dvd writer or Rom from the device manager. After uninstall restart your laptop it again shows new hardware found install it and check it by inserting some working disc in it. Or if it not solve your problem Try using Microsoft fix it center.
Insert disc 1 to install game, but ejcts the DVD. What do we do?
file missing from Dvd (dx.inf) kindly get the game replaced
Whenever I insert discs into my Dell studio laptop, nothing will come up, even when i click on my computer. Ive tried multiple discs and nothing works.
Hi, I have a Dell Studio 1558 Laptop. I have a dvd stuck in it. If restarted it will detect it initially but as i press eject button or right click the drive n click eject, then it shows no disc in drive....
Take a paper clip and straighten it. Easy goes - insert it in the small hole in the tray, just a little at a time. When you start to feel resistance, gently push a tiny bit more, and the tray will open. But do remember - be careful, don't just jam it in or you may damage your DVD as well as your tray. Sounds like you may need to have a new drive installed.
1helpful
My dell studio 1737 keeps making clicking sound and wont eject tried my computer, tried funtion key not doing anything please help
It sounds like your CD/DVD rom is stuck or damaged. If the drive is empty, this means that something is wrong with the drive itself.
Often, you can use a paperclip that has been bent straight to open this. insert the paper clip into the tiny hole on the door pannel of your CD/DVD drive and most of the time it should pop right open.
if it does not pop open right away, I have seen situations where the disc becomes lodged inside the case and will not allow the door to open at all. This may require you to take your laptop to a repair facility and explain the situation to them.
If you are feeling very confident, you can try to remove the CD rom drive from your laptop, remove the outer casing and see if you can dislodge the disc that way.
1helpful
2answers
DVD writer not detecting the disc and not ejecting the Cd after.
You may have to restart your computer so the hardware can work.
Can the dell 17 studio accept a mini disc from my camrecorder? I have a mini disc (2X1.4 GB - 30 min.) from my camrecorder. You can not see the tray in the dell 17. I do not want to insert the disc without...
hi,
How do I eject a disc from a Dell Studio laptop? It doesn't have a tray or door. You just slide the disc into the slot. I was adding Norton Antivirus software to the computer. It took the CD into the slot...
There should be an eject button next to the cd slot.there has to be,if its broken theres a small hole you can insert a paper clip and itll eject the cd.Buttton.But look for that button there small!!
1helpful
3helpful
2answers
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
