Just purchased a treo 650. It has a camara but didn't come with the application installed. I have my old 650 which has the application but it won't beam or transfer over. how can I get the camara application on my new (used from e-bay) phone. thx shane
SOURCE: Treo 650 keyboard stuck
Sure. This involves taking the phone apart. Fortunately, it isn't difficult. Go to "mytreo.net, and find the BUZZ FIX. It will give you instructions with photos of how to open your 600 and perform the BUZZ FIX. Do that while you have the phone open. You will disconnect the battery in that process. Carefully lift the board that the battery is mounted on and this will expose the KEYPAD. Remove it, clean the keypad, and the pressure contacts below it -- carefully with a Q-tip and a little water and perhaps a little alcohol. Put the keypad back in place. Put the board back in place. Reconnect the battery after performing the BUZZ FIX (you may as well do it while you have the unit apart because you will have the buzz sooner or later). Put the case back together. Tighten the screws. Turn the unit on and make a call. If it doesn't work then you are in trouble.
SOURCE: Resurrection
Sadly the chances are not high. the bootload screen tells you that Palm OS has not even loaded, assuming you have tried a soft reset this would suggest that the devices memory is either inaccessible or damaged. Anything you try is going to be a slim chance but what do you have to lose by trying? If you reset your palm with it plugged in to your PC via a USB cable there's a small chance you may force it to act as a USB memory reader, as such it will show up in My Computer as a drive or if you have a memory card in the phone it will show up as 2 drives. I cannot stress enough that this is a slim chance though. If you are familiar with telnet and serial data communications it is stall possible to access a palm this way and possibly find your data, however this is a very involved procedure that will require a steep learning curve if you don't know what I'm talking about and still represents a very slim chance.
SOURCE: treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
SOURCE: unlock code for palm treo 650
sign up at mytreo.net I was able to get an unlock code program for my treo 600 there
SOURCE: Palm Treo 650 Smartphone
Check out what is available on the Palm website: www.palmone.com
Go to support, downloads, then pick your model (Treo 650) /and/ your service provider.
